First post, by VioletGiraffe
Just received an order of two ISA sound cards the other day (second-hand, ofc), and I have a trouble setting them up. I'm starting to think I'm doing something wrong. I'm using The Secret Of Monkey Island for testing, and when I run it with "monkey a" command, I get no sound out of the card's line/speaker out. I have an amp and a pair of speakers connected so it's not an issue of trying to drive an ampless speaker from line out.
The "a" switch is said to select Sound Blaster mode, but my card is claimed to support Sound Blaster Pro and WSS mode (not sure what that is), not just Sound Blaster. Is there a different switch for the Pro mode? I have failed to find a list of command line options for monkey.exe.
My card is exactly the same as this one: http://www.vcfed.org/forum/showthread.php?394 … ound-Card-Cheap!
I have downloaded and tried these drivers: http://www.vogonsdrivers.com/getfile.php?file … &menustate=36,0
The setup.exe there is for Windows only ("Cannot be run in DOS mode"), but Sndtune.exe works and shows something like: "82C931 detected... Configuration OK!". oddly, though, readme says that sndtune also supports "/?" switch to display command line options, and on first launch it should bring up a configuration utility, but no. Whatever command line switch I try, it always prints "OK!" and quits.
So, I guess, my questions are:
1) Do I need different drivers?
2) Do I need a different mokey.exe command line option(s) for it to select my card?
3) Do I need a different, more reliable game to test the card with?
4) Is this version of the game even supposed to have sound, apart from the internal speaker which does work? Screenshot attached. I got it from one of the popular abandonware websites.
20.79 KiB
My AUTOEXEC.BAT:
LH /L:0;1,45456 /S C:\DOS\SMARTDRV.EXE /X
@ECHO OFF
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:\DOS
C:\NC\NC.exe
CONFIG.SYS:
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM
BUFFERS=15,0
FILES=30
DOS=UMB
LASTDRIVE=E
FCBS=4,0
DEVICEHIGH /L:1,12048 =C:\DOS\SETVER.EXE
DOS=HIGH
Any advice will be highly appreciated.
Almost forgot: I set the PnP jumper to Enable and IDE jumper to Disable on the card, is it correct? And I inserted it into the long slot as it fits, not in a shorter ISA slot. (I don't know the right names for these two types of slots and what is different between them, going to google it now).
Reply 1 of 22, by Baoran
I dont know if it makes a difference because I always have it there, but I see you dont have the blaster variable set in autoexec.bat
https://retronn.de/imports/soundblaster_config_guide.html
Reply 2 of 22, by VioletGiraffe
Thanks! Is your card a true SB, or just compatible? That guide says to use CTCM.EXE for configuring fully PnP cards (which mine is), but obviously I don't have that executable as it's not a real SB card.
Reply 3 of 22, by Baoran
I don't know which card you have so I don't know how it is configured exactly. The blaster variable is for the software that you run if it has been programmed to check blaster variable for which address, irq and dma it needs to use to find sound blaster compatible card.
Reply 4 of 22, by VioletGiraffe
That I understand, but the variable is not supposed to be set by hand if the card is fully PnP-compatible, if I'm reading it right. My exact card is linked in the question, by the way (http://www.vcfed.org/forum/showthread.php?394 … ound-Card-Cheap).
Reply 6 of 22, by cyclone3d
You must run the DOS configuration utility for that OPTi931 based card before it will work.
See here for info:
https://flaterco.com/kb/audio/ISA/index.html#OPTi931
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 22, by Grzyb
You need to run that SETUP.EXE under Windows 3.1 to properly install the software.
It should install SNDINIT.EXE, which needs to be added to AUTOEXEC.BAT to initialize the card on boot.
Reply 8 of 22, by VioletGiraffe
Thanks, but I don't have Win 3.1 to install the software from! Is it not possible to get it working in MS-DOS 6.22?
I tried running SNDINIT.EXE manually and it says "OK", but as you know that's not enough.
Reply 9 of 22, by cyclone3d
I'll look and see if I can find an already extracted version of the driver and if not, I'll extract it since you really don't need the installer at all as long as you have the files.
A bunch of companies used to do that back in the day... make you run an installer in Win3.x to extract the DOS drivers.. so dumb and angered me even back then.
I have at least one OPTi931 based card so I can test it as well.
YMF7x4 Guide
Reply 10 of 22, by VioletGiraffe
Thank you, I will very highly appreciate that and toast to your health! And we could upload the drivers to Vogons archive, I presume?
I would install Windows 3.1 if the solution is a s simple as that, but I can't at the point since I don't have the disk space. I have IDE to flash adapters on the way, but still ways off.
Reply 11 of 22, by cyclone3d
Ok, try this DOS driver installer:
opti_82c931_msdos.zip
303.52 KiB
57 downloads
1. Extract files to floppy disk
2. Boot to DOS or Windows 9x.
3. If in DOS, just go to drive A: and then type install.bat. If in Win9x, open up a DOS command prompt and go to drive A: and type install.bat.
This should set up everything for you and hopefully it will just work.
If not, I'll do testing on my end.
YMF7x4 Guide
Reply 12 of 22, by VioletGiraffe
What did you set SOUND16 variable to?
P. S. According to this, it should be set to the root of the drivers dir, but then sndinit complains: "No language file found, setup aborted."
Reply 13 of 22, by cyclone3d
I didn't make that install. The batch file should set it to the drivers folder I think.
I'll test on my end here. Maybe that driver package isn't complete. Looked to me like it may have been a user made install.
YMF7x4 Guide
Reply 15 of 22, by VioletGiraffe
I think the version of The Secret of Monkey Island I have is severely trimmed down and isn't supposed to have sound besides the internal speaker. Which game or application would you recommend for testing if a sound card works? Specifically, an SB Pro compatible card and an OPL3 sound card?
Reply 16 of 22, by cyclone3d
I went through my collection last night. I have 6 different OPTi931 based cards. 3 without onboard wavetable and 3 with onboard wavetable.
I'll test with that DOS driver install. If that doesn't work, I'll swap out the drive and install Win3.1 and then do the regular install from there. That way I should be able to get the default config that the regular installer makes.
There really should also be a DOS configuration program that let's you change the configuration.. but that is based on my experience with the OPTi930.
YMF7x4 Guide
Reply 17 of 22, by VioletGiraffe
Thanks, I would very much appreciate that. I can't even run Win 3.1 or 95/98 on a virtual machine because my main PC has virtualization problems (or, rather, Oracle Virtual Box and VMware have problems with Windows hypervisor which I need for other things to work here).
Reply 18 of 22, by cyclone3d
Ok, so it worked right away for me... but I did comment out the CDROM driver line in config.sys that it put in there.
What does your config.sys and autoexec.bat files look like now?
I think we may just need to edit them a bit to make it work.
Also, if you run sndinit it will bring up the configuration program.
YMF7x4 Guide
Reply 19 of 22, by VioletGiraffe
cyclone3d wrote:
Ok, so it worked right away for me... but I did comment out the CDROM driver line in config.sys that it put in there. […]
My config and autoexec files look the same as posted in the opening post except I added the SOUND16 variable that is set to the folder where I placed the contents of the driver package you gave me yesterday.
sndinit doesn't bring up anything - as I explained, it just says: "Language file not found. Program aborted." and quits. I assume there are necessary bits which you have but which were not included in that package.
