Reply 2520 of 5157, by Caluser2000
My wife has a couple of those lamps out in her work shop.
Reply 2521 of 5157, by wiretap
Saved from the dumpster at work. The modem was used to interface with a meteorological tower Climatronics system to provide weather information to the nuclear plant process computer, the laptop was just a general workstation for looking up plant components in the main control room, and the headsets plugged into the HI-COM system to talk with other people around the plant (relay room, main control room, etc)
NEC Versa 6200MX
Codex 5212R Motorola ACU modem
2x David Clark H5030 headsets w/ mic (I'll probably use these in my Humvee -- they appear to still be manufactured, despite not being used since the early 90's) The cool thing with these -- no amp/headunit required: just talking generates the power needed to hear it in the other headset. Clip them together with the alligator clips, and you can talk to each other in high noise environments.
My Github
Circuit Board Repair Manuals
Reply 2522 of 5157, by Miphee
Got this Supertron SV1482 yesterday that was wasting away in the attic at some guy's house.
After a cable change the image isn't half bad, sharper than I expected. Needs extensive cleaning inside and out.
Reply 2523 of 5157, by Standard Def Steve
This was beast was thrown out at the office today:
9YJYKHm.jpg?1
7OKzbdN.jpg?1
I'm thinking this will make one hell of an XP box! Specs are:
-i7-2600K which was actually overclocked by the previous owner to 4.3GHz (and it's fully stable at that frequency @ stock voltage with the dinky Intel cooler--this may be a "golden" 2600K!)
-16GB of DDR3-1600, 9-9-9-24
-Radeon HD 6970 2GB video card. I think this was AMD's answer to the GTX 570?
-256GB OCZ SSD and 3TB hard drive
I just need to stick my X-Fi Titanium in there and it should be all set!
Some initial benchmarks:
3DMark01SE
The attachment 2600K 4.3, HD6970, 3D01.PNG is no longer available
3DMark03
The attachment 2600K 4.3, HD6970, 3D03.PNG is no longer available
3DMark05
The attachment 2600K 4.3, HD6970, 3D05.PNG is no longer available
3DMark06
The attachment 2600K 4.3, HD6970, 3D06.PNG is no longer available
Doom 3
The attachment Doom3.PNG is no longer available
Not bad, not bad. However, this $60 Optiplex 9020 I picked up (and promptly added a GTX 1650 to) consumes 3 times less power, is nearly silent, and outperforms the Sandy Bridge rig.
In the CPU-heavy 3DMark01SE and Doom3 benchmarks, the 3.6GHz Haswell just ran circles around the 4.3GHz Sandy Bridge. That double-bandwidth L1 on the Haswell is making all the difference, I suppose. In 3DMark01SE, the boring Optiplex managed to hit 82,339, and in Doom 3 @ 1024x768 'Ultra', it got 466.2 fps. So yeah, much faster single-threaded CPU performance than the Sandy Bridge. Of course, it can't run XP. 😀
"A little sign-in here, a touch of WiFi there..."
Reply 2524 of 5157, by Horun
Both are Nice for the price !
Reply 2526 of 5157, by cyclone3d
Standard Def Steve wrote:
This was beast was thrown out at the office today: https://i.imgur.com/ItQGrTX.jpg […]
9YJYKHm.jpg?1
7OKzbdN.jpg?1
3DMark01SE
3DMark03
3DMark05
3DMark06
Doom 3
Put the 1650 in the 4.3Ghz system and see how the scores fair. You can't really compare them unless you are using the same exact video card.. especially in 3DMark.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2527 of 5157, by Caluser2000
Found this thing while sorting out my motorcycle parts.
The attachment 20191014_100135[1].jpg is no longer available
Reply 2528 of 5157, by HanJammer
Guy posted on FB group (about vintage synths) he wants to give away this thing - nobody wanted it, and when I noticed his post it was already too late because he throwed it away... but when I contacted him he recovered it from the dumpster and I picked it up today... I have some Audigy cards but with internal connector, I guess it's a goods reason to look for a card with external connector 😉
It came with the cable too.
Reply 2529 of 5157, by chinny22
Nice! did see a few cards been sold without the external box when I was looking to buy one myself. Should sell real nice as a complete package if you don't wan't to keep it yourself and 1/2 of them are missing the cable
Reply 2530 of 5157, by Daniël Oosterhuis
xjas wrote:
Not your typical "retro hardware", but I'm counting it. I lucked into these two '80s style spring-arm lamps by the side of the r […]
Not your typical "retro hardware", but I'm counting it. I lucked into these two '80s style spring-arm lamps by the side of the road tonight. I've actually been after one for ages, but apparently they're so far out of style they may as well have never existed. I remember them being everywhere when I was a kid & now they're just gone. Bizarre. (I'm sure you can probably get them new from somewhere, but I never see them in thrift shops, offices, garage sales, people's homes, or anywhere really, so apparently no one's buying them.)
Fortunately they're in way better shape than the Asus A7V8X was. 😜 There was also a super-'80s stylish red one, but it was kinda trashed and didn't have the spring arm base, so I left it there.
I have a specific spot in my living room where one of these will be perfect. I'll probably use the other one for a reading lamp over my bed. Both areas are badly in need of some extra lighting.
IKEA still has these style of lamps, the TERTIAL which they sell for $9. Not affiliated, but just know of these because I've used two for mic and camera holders. Still want to get one just as a lamp, though.
0487645_PE622662_S5.JPG?f=s
Reply 2531 of 5157, by PC Hoarder Patrol
Still have my original one of these lamps from back then (battleship grey & rust coloured now 🤣 ) still going strong.
Reply 2532 of 5157, by henryVK
I have one of those Flexco lamps from the US sitting in the basement, made by the Art Specialty Company.
Pretty cool, but never got around to converting it to euro-cycles. It looks like this one:
https://www.etsy.com/il-en/listing/695624222/ … industrial-lamp
Reply 2533 of 5157, by oeuvre
wow what a sweet find for free!
Reply 2534 of 5157, by stoof
Since we're talking lamps here all of a sudden, here's what I picked up yesterday:
You can't really tell from the photo, but the beak is blue. Obviously a keeper. 😀
Also yesterday I found:
- a nice vintage philips portable radio, which I think can be sold quite easily.
- A curved samsung display of some fashion. Lacking it's power adapter tho. Will go back where it came from if I can't find an adapter soon.
- A complete LGA1156 PC, ASUS mobo, 8GB of RAM, some videocard AND:
- A Samsung 840 EVO 250GB SSD! Nice. Will be a boot drive for my server.
All in all, a good day for trash pickin'.
Reply 2535 of 5157, by HanJammer
stoof wrote:
Since we're talking lamps here all of a sudden, here's what I picked up yesterday: ... You can't really tell from the photo, but […]
This flamingo is amazing! Also what kind of idiot throws away perfectly good 250GB SDD drive, not to mention LGA1156 platform with 8GB of RAM which still is a decent PC 😮
Don't throw away this Samsung display even if it lacks the power adapter. You can probably mod it into a nice daylight lamp perfect for taking hardware pictures or working on computers. Take a look how to do this: https://www.youtube.com/watch?v=8JrqH2oOTK4
Reply 2536 of 5157, by stoof
Oh cool, that's a good idea.
I've been thinking of making some videos and lighting is a bit of an issue. Now instead of getting those LED-arrays that everybody is using, I could just mod some old screens. Neat!
As for people throwing away good stuff; there are plenty, plenty of those around, unfortunately.
I've been trash picking for a long time, and I've always wondered what makes people thow away good stuff. Nowdays, I can understand why it's done in some cases. Not that I condone it, just understand why.
Reply 2537 of 5157, by appiah4
What I can tell from the photo is that the beak looks like a dong and I can't unsee it..
Reply 2538 of 5157, by liqmat
Would that be a Fladongo at that point?
Reply 2539 of 5157, by appiah4
Possibly. And it probably comes from a strip club. 🤣
