HP Z400 Video issue
First post, by Anaxagoras
Hello.
Recently I receive a HP Z400 Workstation.
It works fine with their graphics card, NVIDIA Quadro FX580, but don't boot up with this other, NVIDIA GeForce GTX280 .
I thought that the problem could be in power supply, because of this I replaced it by another one with 500W.
But the problem persists.
I'm not sure if GTX280 is compatible with HP Z400 mainboard.
This is the Z400's expansion card slot identification.
My computers
Reply 1 of 7, by chinny22
Maybe if you try a card that's more closer related to a officially supported card.
These are the cards officially supported by HP
NVIDIA Quadro NVS 295 256MB PCIe Graphics Card
NVIDIA NVS 300 512MB Graphics
NVIDIA Quadro NVS 450 512MB Graphics
NVIDIA Quadro 400 512MB Graphics
NVIDIA Quadro 600 1GB Graphics
AMD FirePro V3900 1GB Graphics
AMD FirePro V4900 1GB Graphics
NVIDIA Quadro 2000 1GB Graphics
NVIDIA Quadro 2000D (Spec DVI only card)
AMD FirePro V5900 2GB Graphics
AMD FirePro V7900 2GB Graphics
NVIDIA Quadro 4000 2GB Graphics
NVIDIA Quadro 5000 2.5GB Graphics
Looking at Nvidia's in the list they are all Fermi based, so would limit myself to this.
If you want to take even less risk and we use the Quadro 2000 as an example (as it also has 1GB) something based on the GF106 processor
https://www.techpowerup.com/gpu-specs/nvidia-gf106.g83
The maintenance and service guide also says on P91 that the original 475W PSU can handle a total of 150 watt card (or two 75 watt cards) it seems at one point HP upgraded with a 600W PSU in which case the new maximum was a 250 watt card.
https://jp.ext.hp.com/lib/doc/manual/workstat … /504630_001.pdf
Reply 2 of 7, by Anaxagoras
Thank you very much chinny22 for your help.
This info is very usefully.
The original idea was to use this card because I have one (installed in other more slow PC).
But now I have a good start point to upgrade the graphics card in this machine.
Thanks again!
My computers
Reply 3 of 7, by chinny22
No problem, recently dragged one out of retirement at work as a 2nd rendering PC, crappy Quadro NVS 295 but 32GB ram. It just sits in the background crunching away.
Was impressed with the design, nice little machines, needs a 2nd socket though 😉
Reply 4 of 7, by oeuvre
You gotta get a Z600 for the 2nd socket. But yes, HP Z workstations are awesome. Recently got a Z420 and it's a blast of a machine.
Reply 5 of 7, by Anaxagoras
Recently I've upgrade this machine with NVIDIA Quadro 5000.
It's more than enough for my purposes. Honestly, it runs fluently any game that I own.
My computers
Reply 6 of 7, by pentiumspeed
500W is not enough, needs 650W or greater. The Z400 comes with 475W only and uses power hungry components. GTX 280 is earlier than GTX 285 and still about 300W card. Try another PSU with 650W or 750W. my favorite is Seasonic modular models.
Also get this adapter cable to use ATX PSU in Z400:
https://www.moddiy.com/products/ATX-to-HP-Z40 … pter-Cable.html
I have Z220, Z230 and Z420 V2 all works with any GPU cards that I have other than Quadros if can be hooked up and within power limits. I used GTX 960 in two of them. Previously, I had GTX 750ti and GTX 1050ti, and had used HD7750, HD7770, as well, etc ones I forgot about.
If you are handy with modifications:
https://forum.level1techs.com/t/modding-a-des … ples-help/98703
Cheers, pentiumspeed
Great Northern aka Canada.
Reply 7 of 7, by Anaxagoras
Thank you very much pentiumspedd for your help.
This topic becomes more interesting post by post.
My computers
