Reply 20 of 23, by dionb
- l33t++
wrote:[...]
Unfortunately I don't have a DX4 to do the test, and this mainboard only accepts 5V and a DX4 overdrive is really expensive and you have to buy it without going to trial.
Then test it the other way round: underclock your DX2-66 to 50MHz (2x 25MHz). That will keep ISA VGA performance constant and drop CPU performance by 25%. If the slowest parts of the game get even slower, you have a CPU bottleneck. If different parts of the game now get slower, but not much change at the formerly slowest parts, you had a VGA bottleneck.
Note that it's entirely possibly both CPU and VGA are limiting at the same time. In that case upgrading either will help - although as stated the ET4000AX is about as fast as it gets on ISA, if you can't go to EISA/VLB/PCI, your VGA is already maxed out.
