First post, by Predator99
I have now my Forex 80386 board more or less running. I got it as shown in the picture here (# 47) without CPU and Cache:
Re: 80386 BIOS image collection
First it didnt run at all but after some tests I figures out that the Keyboard controller causes trouble. I tested several and found one which works. Also added some Cache.
Now the board starts up:
Everything works without problems (but total amount of RAM does not match). I can enter Setup and save the CMOS-data. But: When trying to boot, it stop at Post-code "A0 9F" on the screen shown above. A0 means...
A0 "(A0)Keyboard ID command issued. Keyboard ID flag to be reset."
or
A0 Program the cache SRAM
Tried several Keyboard controllers (Keyboard works without problems with the one installed!) and tried several Cache-chips but no change. Cache should also not be the reason because you can disable it completely in BIOS.
Then I tries MR-BIOS from here..:
How about a MR-BIOS ROM file repository?
It also starts fine and detects the correct amount of RAM and Cache. But: Keyboard doesnt work at all with MR-BIOS..! 🙁 Strange...
Any idea what I can do?
