Reply 31560 of 53035, by brostenen
- l33t++
wrote:wrote:wrote:Great product.
The V2 is actually quite a big step backwards, buggy and with features removed. Get the V1 instead if you can.
That's too bad. I installed the V1 on a revision 4.x board and it worked like a charm.
I see two issues with it.
One is that I can not update the firmware without a lockup on the V2 that I already have in my Amiga600. And this one that I just recieved, locks up when I try and update the firmware in my Amiga500 Revision 6a that are my 500-Desktop. The only way I can update, or bring it back from a lockup. Is to install it in my Amiga500 Revision 5 machine, and run the Resque disk.
The other is issue is:
If I use a low grade monitor, then it will make some slight ghosting effects in Workbench or other pieces of software, that have white or light grey background. I see nothing in most games.
As for the bricking/locking of the scandoubler. Then I suspect that it is related to the Agnus in some form. Or it is related to over 512k of Chipram. As far as I understand by snooping around on Individual Computers forum, then it is shipped as an OCS devinise setup. There is a setting in the Tool that one can download, in wich it can be kicked into ECS mode. So my guess, is that it might be related to the Agnus. On the other hand. It is running well as of now, and I can not begin experimenting before after X-Mas.
