Odd shutdown problem
First post, by GrampaGotTheKeys
I recently added a second hard drive as a slave to my Windows 98 SE machine, the mobo is a MSI MS-6156.
It starts and restarts just fine but when trying to shutdown it spends about 5 minutes on the "Windows is shuting down screen", the screen goes black but the pc is still on for another 5 minutes until it finally shuts itself off.
If I removed the second hard drive it shuts down just fine in a snap!
I have tried swapping out the second hard disk with a different one but the problem persists.
Was hoping someone might have a solution other than just sticking to a single drive as the 32GB limit isn't ideal!
Reply 1 of 2, by derSammler
Install Windows 98 SE Q239887 Update.
Reply 2 of 2, by GrampaGotTheKeys
derSammler wrote on 2020-01-09, 16:58:
Good suggestion, tried both shutdown supplements to no avail.
I did a test and it even happens under DOS so looks like i'm going to need to give up and simply say it's down to hardware (motherboard).
