First post, by GigAHerZ
- Oldbie
Hi!
I have an amazing Socket 3 VLB board Soyo SY-25P:
https://stason.org/TULARC/pc/motherboards/S/S … SY-25M-N-P.html
Need help finding 486 VLB Board information and Manual (Someone's thread with good picture and additional information)
It's a Sis 471 based board: ftp://retronn.de/docs/chipset/SiS%20471.pdf
It has 4xDIP32 + 5xDIP28 sockets for cache. I have 4x IS61C1024 + HA24257AKC for tag, that should give me 512kB of cache.
Now, the problem is, that there is no jumper setting to set it up for 512kB of cache. I've tried 3 jumper selections, each with 3 positions (1-2, 2-3 and open) all combinations, but never got 512kB on my screen. It works well as 256kB total cache with those chips.
Looking at the datasheet, it describes Register 51, where theoretically you could even have 1MB of cache. For both 512kB and 1MB, additional bit is needed to be flipped compared to the lower capacities.
Using modbin, those bits are not changable by software. (I was able to enable proper writeback support a while ago with bios modification. This board otherwise has a bug with writeback)
I assume, that bit is held constantly at 0/low by hardware means.
Is there someone who could help me figure out, what i could maybe do to flip that bit? Where to look, what to test?
Thank you!
