First post, by oeuvre
Since this is a common issue, figured why not just have one topic where people can ID motherboards. Fire away!
Reply 1 of 11, by The Serpent Rider
This board:
1.1 MiB
Markings on the back:
LITE ON 20V0
9546-03
486IP-B-2-A
Initially I thought that it was Silicon Star motherboard (PI4/PI4T PCI), but jumpers don't match 100%. I'm also aware that Soyo had the same design (SY-030G/H), but jumpers are different too.
Reply 2 of 11, by PcBytes
The Serpent Rider wrote:
This board: […]
This board:
LITE ON 20V0
9546-03
486IP-B-2-A
Initially I thought that it was Silicon Star motherboard (photos), but jumpers don't match 100%. I'm also aware that Soyo had the same design, but jumpers are different too.
Wim's BIOS says it's mf'd by Beyond.
BIOS string: 10/02/95-SiS-496-497/A/B-2A4IBB61C-00
Reply 3 of 11, by oeuvre
Also would be a good idea when you can to include a picture of the underside of the motherboard.
Reply 4 of 11, by The Serpent Rider
No jumper config information unfortunately.
Reply 5 of 11, by bjwil1991
Markings:
KM266PRO-MLV
Rev. B1
VIA VT8235
VIA KM266PRO
This board is in a CBW Diplomat PC.
It currently has an AMD Duron CPU installed, 128MB DDR RAM. Also has an AGP 4x slot and 3 PCI slots.
Reply 7 of 11, by bjwil1991
Repo Man11 wrote:
It doesn't have SATA ports (although, there are outlines for it). Close.
Reply 9 of 11, by bjwil1991
Thanks. Haven't seen or used a DFI board in years. I had a P5BV3+ Rev. B+ from 1999-2009 and it was amazing for a high end Super Socket 7 board (100MHz FSB, AGP 2X, and 768MB RAM maximum) and I updated the BIOS to the latest version to support the 80GB HDD I had.
Reply 10 of 11, by PcBytes
Interesting thing is that DFI boards were also sold under the Canyon name.
For example,Canyon's 9I6PEA-L is actually a DFI PS83-BL (i865PE).
Reply 11 of 11, by FelixNZ
Hi, First time poster - I picked up a socket 7 board for a pentium 1 system recently and can't find any identifying marks on it, but it's a 430VX system, has a single USB header, CoaSt slot and both ISA/EDO and PCI/SIMM slots. Thankfully all the jumper settings are pretty clearly printed on the board. The only clue I've found is the holographic sticker which has a smiling sun character above some chinese characters, and the words "Acer" (although I haven't been able to match this layout to any other acer boards online) and "Amico" tiled behind it.
    1.85 MiB
