Reply 32460 of 58436, by RacoonRider
appiah4 wrote on 2020-02-12, 09:35:
(I can't post the photo because the new site has issues with images that contain the word RAGE in the name, apparently..)
If only ther was a way to rename files!
Reply 32461 of 58436, by appiah4
RacoonRider wrote on 2020-02-12, 10:58:
Interestingly enough, I can't even attach it to the post as an image despite renaming the file.. The board keeps throwing the following error when I submit:
Some attachments are no longer available. Please check and re-attach any missing files.
EDIT: Apparently the issue got fixed?
Reply 32462 of 58436, by konc
appiah4 wrote on 2020-02-12, 11:24:
I got the same message, for no apparent reason I couldn't attach a photo with a simple name like abc.jpg. I posted the message and then edited the post and it worked.
Reply 32463 of 58436, by appiah4
konc wrote on 2020-02-12, 12:11:
Interestingly enough I also managed to edit my post above and link to the hosted image..
Reply 32464 of 58436, by Slashzero
Also if you mention BSOD. If you look In the “help with cpu-z“ thread, I was trying to post a BSOD image I got when trying to start CPU-Z. The forum was blocking my image stating that basically “meme (reaction images) were not permitted in these forums.” I somehow got it to eventually accept the screen cap though it was a bit strange to see that error. There must be some auto-mod logic that searches posts for key words? But I specifically got the error only when I uploaded the image and tried to submit the post. I was just trying to help the developer out with a screen cap of the error, not posting a BSOD meme. 😜
Reply 32465 of 58436, by gex85
The only PCI card that I need/want now is a Savage4.
Me too. Some time around the year 2000 I had a secondary system, based on the AOpen AP5S and a Pentium 200 non-MMX (still have the board and CPU in storage). The graphics card used to be some sort of S3 Virge and I wanted to throw in something more powerful. So I got the Diamond Viper V550 PCI (TNT), only to find that the system wouldn't POST. So I returned the Viper and got a Creative S3 Savage4, CT6850, which worked well, but was quite a bit behind the TNT performance-wise.
Unfortunately I don't have the Savage4 any more, probably it was scrapped together with a box of other stuff some time between 2006 and 2010, a few years before I really got into retro computing.
Now I am looking for decently priced CT6850 just because of the nostalgia, but they show up rarely and are usually priced at >50€, which I find is too expensive for a card that I wouldn't use on a regular basis. Guess I'll just wait 😄
My retro computers
Reply 32466 of 58436, by imi
some random stuff ^^
MA5ASOUND Avance Logic ALS100 and a WD MFM ESDI controller (finally with cables ^^)
The attachment hardware36_15.jpg is no longer available
Aztech Sound Galaxy NX PRO 16 and a very intriguing EIZO AA41 (CAD accelerator?) card
The attachment hardware36_16.jpg is no longer available
and this very nice Videologic (Genoa?) GrafixStar 500 S3 Vision868 VLB card :3
The attachment hardware36_17.jpg is no longer available
Reply 32467 of 58436, by Predator99
Very nice, Imi 😉
Do you have drivers for that EIZO card?
You should double check the MFM controller if its really MFM/RLL and not ESDI before connecting a drive to it...
Reply 32468 of 58436, by blurks
Genoa box doesn't belong to the video card (no connection/affiliation between Genoa and VideoLogic). There is a picture of the original box some several hundred pages ago.
Reply 32469 of 58436, by imi
Predator99 wrote on 2020-02-12, 19:54:
Very nice, Imi 😉
thanks for the heads up, it looks like this is indeed a ESDI controller ^^ good eye
unfortunately I do not have any drivers for the EIZO card, and I didn't find a lot of info about it in general, but I did get the perfect card to go along with it eventually a while ago ^^
The attachment hardware35_17.jpg is no longer available
blurks wrote on 2020-02-12, 19:54:
yeah, I figured as much... but the funny thing is that I only found this listing because I was specifically looking for Genoa cards x3
Reply 32470 of 58436, by RacoonRider
imi wrote on 2020-02-12, 20:15:
Sounds like a reason for refund 😀 Just kidding, I know you are better than that.
Reply 32471 of 58436, by derSammler
Got (another) box of RAM today - mainly PS/2 and PC100 SDRAM. Really need to get something up and running to test the 300+ RAM modules I have now.
//edit:
Attachments don't work, so no picture.
Reply 32472 of 58436, by dr.ido
imi wrote on 2020-02-12, 17:46:
... a very intriguing EIZO AA41 (CAD accelerator?) card
Interesting - It doesn't look like a typical TIGA card. The piggy back ISA connector is likely for an optional EGA or VGA card - This card probably doesn't do any standard PC modes or DOS text modes.
Reply 32473 of 58436, by derSammler
I've got Win3.1 drivers for Spectragraphics cards. Can't attach anything here, however.
dr.ido wrote on 2020-02-13, 10:03:
Why do you even think this is a TIGA card? I'm pretty sure it's a VGA card supporting the DGIS api, because that's what Spectragraphics was known for.
Reply 32474 of 58436, by wiretap
IBM 6181682 Floppy Controller ($9):
Floppy Cable for controller above ($5):
Cirrus Logic GD5428 VLB ($12):
Siig Suntouch K101 XT/AT Switchable White Alps Keyboard ($29):
My Github
Circuit Board Repair Manuals
Reply 32475 of 58436, by imi
derSammler wrote on 2020-02-13, 10:20:
I've got Win3.1 drivers for Spectragraphics cards. Can't attach anything here, however. […]
that'd be awesome, thank you, maybe could upload them somewhere.
I think the card can just interface through the normal feature connector too.
it'd be interesting to know which software supports it too... I think I have an old acad R12 somewhere.
RacoonRider wrote on 2020-02-13, 05:04:
well, I'm not complaining ^^
Reply 32476 of 58436, by derSammler
This time it apparently worked. 😀
Reply 32477 of 58436, by Xicor
I present to you my latest acquisition, the ultimately pointless Ageia PhysX. Don't really know why, but I'm attracted to this type of acceleration cards.
Edited:
The attachment AgeiaPhysX.jpg is no longer available
Now, where shall I put this thing ? P4 or C2D ?
Probably I may go with a 680i +C2D and a 7800gtx that I have laying around. what do you think ? Is it even worth the hassle ?
PS: Having the "Reaction image posts are off-topic on VOGONS." problem ... does anyone has it too ? Or am I doing something wrong ?
Reply 32478 of 58436, by devius
Xicor wrote on 2020-02-13, 12:46:
Seems to be a recent issue. Some users reported success by editing the post and adding the images afterwards.
Reply 32479 of 58436, by Xicor
devius wrote on 2020-02-13, 12:54:
The workaround seems to fix the issue. Obrigado (thanks) !
