Reply 32580 of 58436, by ragefury32
Took delivery of a Compaq Evo n600c - suppoedly the "ultimate DOS compatible" 2 spindle P3 laptop,.
Why? Tualatin P3m CPU (all the way to 1.1 GHz), i830MP chipset, ATi Radeon M6, and an ESS Maestro 3/Allegro chipset, which is supposed to offer both DOS mode SB emulation and AC97 support all in a relatively svelte 5 lb package (technically the Dell Inspiron 8100 has the same audio chip and a Geforce2Go or Radeon M7, but that machine uses the older i815EP which limits it to 512MB of RAM, while this one can do 1GB. The 8100 is also bulkier at 7 lbs - the Evo n6x0 series is arguably one of the last truly Compaq machines made before the HP accquisition - Thanks Carly Fiorina).
Of course, it's still just a Radeon M6 (no hardware T&L, and ATi is buggy in older DOS stuff), and the Maestro doesn't do FM synth so audio quality in DOS is...kinda questionable. Came with 128MB of RAM, a 20GB HDD, a DVD/CDRW drive and a dead battery (both primary and the ML1220 within). Oh well, some minor work needs to be done, should be able to use most of the configuration from the Dell Latitude C600 that I also have.
Reply 32581 of 58436, by appiah4
Deczor wrote on 2020-02-20, 02:19:
OFFS. How the shit did I not notice that? […]
Hahhhaaaa just the bracket is upside down. WOW Deczor did you do that ?
Fuck, I'm an idiot.
Yes, I did that when I was cleaning up the brackets. I guess it'll actually be a problem if I ever find a case for this thing. The old one is scummy as hell, so was just planning on maybe screwing the pentium to my office wall until I find a case I like
Just remove, reverse and refit the bracket.
Reply 32582 of 58436, by Deczor
Nah. I'll just leave it for now. It's not hurting anyone.
Reply 32583 of 58436, by H3nrik V!
ragefury32 wrote on 2020-02-20, 05:52:
Took delivery of a Compaq Evo n600c - suppoedly the "ultimate DOS compatible" 2 spindle P3 laptop,. Why? Tualatin P3m CPU (al […]
Cool! That i830MP chipset apparently is not very widely known ..
"2 Spindle"? What do you mean with that?
Reply 32584 of 58436, by Joseph_Joestar
Got an Athlon64 3700+ and a Duron 700 for 5 EUR each.
Both seem to be in great condition so I'm looking forward to trying them out when I get back from my business trip.
My retro builds
Reply 32585 of 58436, by imi
oh ffs... seriously?!
The attachment hardware36_19.jpg is no longer available
WHO DOES THAT
there is tape all over the box, and the DHL label is glued on the box too, pretty sure the plastic wrap was added by my forwarder after the fact seeing as it's over the original label and only their label is on it.
I'm mildly angry. idk how to remove all the tape and the label without further damage to the box.
why even bother mentioning it has the original box in the auction if you are going to send it like that.
Reply 32586 of 58436, by Ozzuneoj
imi wrote on 2020-02-20, 10:58:
oh ffs... seriously?! […]
WHO DOES THAT
Wow, that's bad! I had someone send me a boxed ATi Wonder 16/Plus 1MB and it was only packed in one of those plastic packing bags with no padding to protect the box. The box was already fairly beat up so they wrapped the sides in packing tape to make it rigid enough to hold up in transit. If the tape had at least been applied smoothly or evenly I wouldn't have cared much but it had folds and wrinkles in it. There's obviously no way the tape is ever coming off a box from 1990 without pulling all of the printing off with it. They did end up sending me the bus mouse that was supposed to be in the box with the card (they had it listed separately and I didn't notice it), so that was good of them.
I've had a lot of stuff sent to me lately with little or no packaging and lots of damage. Also, I've found that any late AGP cards have about a 15% chance of being intact unless you get them in a computer or in their original box. It's like people can't comprehend the laws of physics when they throw a bunch of cards in a box with a few scraps of old packing material dropped in loosely. If one card has 32 ounces of copper attached to one side, it's probably going to shear off all the tiny sand-like components on the other side when it scrapes against another card's bracket. Oy... I think I have had three BFG 7800GS AGP cards, and more than half a dozen other 6800/7800 series AGP cards, all with smd components scraped off either in transit or in storage before they were sold.
Reply 32587 of 58436, by Sago7
Hello.
This is my actual proyect Building an Athlon XP Configuration on this days. This is what I got.
In my plans, there were a ViewSonic E70f+(17") that I bought a couple of months ago.
But, yesterday I found this for 15USD:
ViewSonic G90fb
It's in very good condition. i'm quite happy with this purchase. Since I never saw one of this in the past.
Now I don't know if I should sell the E70f+ or keep it.
Reply 32588 of 58436, by appiah4
WHO DOES THAT
🤣, that seller is 100% a troll.
I got a few things in the mail, first an ASUS P2B-F with a Coppermine capable Voltage controller, and a PIII-550 Coppermine:
And my new toy arrived:
IBM-PS1-2155-593-Original-State-01.jpg IBM-PS1-2155-593-Original-State-02.jpg IBM-PS1-2155-593-Original-State-03.jpg
IBM-PS1-2155-593-Original-State-04.jpg IBM-PS1-2155-593-Original-State-05.jpg
This will be an interesting and challenging restoration project as it lacks not only some hardware but also some actual case components I will have to design (thanks to @Deksor who volunteered to help) and 3D Print.
Reply 32589 of 58436, by cyclone3d
WHO DOES THAT
I would ask for a big discount / partial refund.
You should be able to use a hairdryer to heat up the label and the tape and remove it very carefully with the hairdryer keeping the label / tape hot while you are doing it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 32590 of 58436, by brownk
cyclone3d wrote on 2020-02-20, 15:07:
WHO DOES THAT
I'd second this. Since it's fresh tape, you have a higher chance to remove them all with minimal to no amount of damage. It will help if you set individual sections and work one by one like restoraton job.
Reply 32591 of 58436, by imi
well, I got the tape off with my heatgun, was fairly easy after all, but the box is pretty torn up anyways 😒
The attachment hardware36_20.jpg is no longer available
at least everything was inside, the card itself has a damaged simm socket, but that was apparent in the pictures already :\
anyways... to lighten the mood, here's some other stuff that arrived recently
Terratec Producer Phase 88 (those terratec boxes really aren't that robust, are they ^^)
SB Live CT4620+CT4660
and a ThinkPad X21 with docking base
The attachment hardware36_21.jpg is no longer available
The attachment hardware36_21b.jpg is no longer available
two hitachi caddy drives with hitachi bus, one more CD-Rom interface ^^
a CD/PD and a DVD-Ram/PD drive and some PD disks
The attachment hardware36_22.jpg is no longer available
and then there's this... I told myself I wouldn't buy any more midi modules for now... but oh well... "oops" ^^
Roland SoundCanvas SC-88 Pro
Miditemp MP-88 midi player/router, I hope it will work the way I intend to use it to route multiple sources to my modules
and a SCSI drive unit all together in a SKB case.
The attachment hardware36_23.jpg is no longer available
Reply 32592 of 58436, by appiah4
You like Terratec cards. I like you. But I also hate you because that means we will probably be competing. Grr..
Reply 32593 of 58436, by imi
wait, I thought we're far apart x3
that reminds me, I forgot to take a picture of the EWS64S with digital extension ^^
The attachment hardware36_24.jpg is no longer available
Reply 32594 of 58436, by ragefury32
H3nrik V! wrote on 2020-02-20, 08:44:
Cool! That i830MP chipset apparently is not very widely known ...
Oh yeah, the i830MP Almador-M mobile chipset. Intel killed the desktop version when they did the big push to P4+RAMBUS, but on the mobile end Rambus didn't have a solution (the P4m were also terrible, power consumption-wise), so Intel's arms are twisted to offer a Tualatin+PC133 solution. The mobile space never got a P4+RDRAM solution, and for the i845 P4 chipset they used DDR instead (which was arguably better). The Almador-M was found in quite a few machines (Thinkpad T23, X22-24, Compaq Evo n600c, Dell C610), but the deluge of P4m stole its spotlight - smart money held out for the Pentium-M, and comparatively few mainstream P4ms were sold. At similar clock speed the Tualatin+i830 were better machines than the Norwood P4+845MPs, but the Norwoods can be clocked much higher. In a way the Pentium-M Banias + i855PM was the better solution - P6 but with a 400MHz Netburst FSB, ICH4M southbridge with native USB2 support, and much more comprehensive speedstep support. It was so good some made it onto boutique SFF desktops.
Oh, the spindle thing? Back in the 2000s back when machines still have spinning drives, the number of spindles denote how many spinning drives it has, and hints at the size/bulk of the machine. For example, a Thinkpad X24/Vaio SR17/Dell D420 ultraportable will be considered a one-spindle. A mainstream Latitude C640/D600 or Thinkpad T22 will be a 2 spindle (one hard drive bay and one optical drive in the hot swappable bay), and a 3 spindle will be something with a bullt-in floppy, an HDD and an optical drive, like a Thinkpad A31p or Dell Inspiron 8100. Of course, a 2008 Dell E4200, a 2011 Samsung NP900 X3A or a 2013 MacBook Pro 13 will be a zero-spindle by that definition despite their rather substantial difference in size.
Reply 32595 of 58436, by appiah4
imi wrote on 2020-02-20, 19:16:
Such a beautiful card. If I had a GUS I'd definitely trade it away for an EWS64XL.
Reply 32596 of 58436, by Turbo ->
Got these three AT computers a few days ago. Already cleaned them a bit.
The attachment IMG_9254.JPG is no longer available
These components were inside:
The attachment IMG_9256.JPG is no longer available
ATC-1425B, but without CPU
The attachment IMG_9257.JPG is no longer available
And some socket 7 motherboards
The attachment IMG_9258.JPG is no longer available
The attachment IMG_9259.JPG is no longer available
Reply 32597 of 58436, by SpectriaForce
Predator99 wrote on 2020-02-19, 10:30:
Dont think the other AGP cards are of interest? Maybe the one in the middle (GF7300GT).
Dual voltage AGP GF7 card? That's quite an unicorn!
Reply 32598 of 58436, by SpectriaForce
dionb wrote on 2020-02-19, 10:08:
Warum??? […]
imi wrote on 2020-02-19, 00:43:
well idk, like I said I never had a Model M before ^^
I was going by wikipedia: https://en.wikipedia.org/wiki/Model_M_keyboard
according to that the german rubber dome variant has the gray on oval logo as well.
Warum???
All the other internationalized versions have blue logo, I'm looking at a 71G4622 (NL version) as I type this.
but it is a 1391403 built in 1988 😀
looks quite good for 32 years honestly ^^
Nice, one of the second generation, shipped with PS/2. Solid as hell.
The color of the IBM label has nothing to do with the contacts (switch or not) between keycaps and membrane type. The blue logo indicates a more recent production date and costs savings, I believe IBM started using them somewhere in 1992 or so. Rubber dome versions do have a distinctive model number.
Reply 32599 of 58436, by appiah4
SpectriaForce wrote on 2020-02-20, 21:34:
Just because it's keyed for dual voltage doesn't necessarily mean it actually supports that..
