First post, by tanasen
Ι 've found locally two boards: the Asrock 775i65G R2.0 and the Asrock 4CoreDual-VSTA. I'm thinking of merging two of my systems into one. The dedicated WinXP PC consists of a P4 3.0GHz HT, a Fujitsu D1675 board, 2x1GB DDR-400, SB X-Fi Platinum, XFX HD4650 512MB AGP, which performs ok but struggles a lot in cpu intensive titles and obviously the P4 chokes the HD4650's performance. The other system runs Win7 and WinXP and consists of a Q6700, a Fujitsu G31T-M2 board, 2x2GB DDR2-800, SB Audigy SE, GTX750 2GB which is an excellent all rounder but nothing special. I want to build a fast AGP system and maybe purchase an HD3850 in the near future. I also want to run a modern OS as secondary for convenience and maybe try some DX10 games. Also with these boards I could experiment with Win98 using an older gpu like the FX5900XT which I have in my possesion...
I was thinking of getting the 775i65G and put a Pentium E5800 in there and along with my HD4650 (for now), a couple ssd's and 2x1GB DDR-400 this would make a pretty fast (and cool) system for WinXP and it should still be usable for a more modern OS like Win7/8.1. But today I found the 4CoreDual-VSTA and after doing a little bit of reading in the vogons threads I think I'm better off with this one. This board should work with the Q6700 (downclocked though? so maybe the most suitable processor would still be the E5800? ) and with more than 2 GB of DDR2 RAM (it has a limit of 3.3GB?) but only with the correct modded BIOS, which I'm not sure which one it is. So what do you guys think? To me the 775i65G seems like a low risk choice but the VSTA is probably the most versatile board but maybe a PITA to find the correct configuration.
PC1😜 III-S 1.4GHz, GA-6VTXE, 512MB SDRAM, Albatron FX5900XTV 128MB, SB Live! 5.1
PC2😜 III 800MHz, MS-6178, 256MB SDRAM, 3DFX Voodoo3 2000 PCI, Creative CT4810
PC3😜 MMX 200MHz, SY-5EAS5, 128MB SDRAM, Diamond Monster 3D, Diamond Viper V330, ESS 1868F
Reply 1 of 17, by The Serpent Rider
Asrock 4CoreDual-VSTA is not recommended to use with quads without VRM mod.
Reply 2 of 17, by Shagittarius
I use a Xeon3230 w/ 4CoreDual-VSTA without any mods and haven't noticed any issues. What kind of issues are you talking about?
EDIT : Just looked this up, apparently it only matters if your running a PCIe 2.0 card? I'm running strictly AGP on mine so I can run 98 and XP.
Reply 3 of 17, by The Serpent Rider
VRM is a bit too weak for quads and it may run unstable. If you want to use this board for a long time, you should not overburden it.
Reply 4 of 17, by Shagittarius
I had to find ram that I could run at full speed but I haven't noticed any instability and I'm not looking to overclock. Still, do you have a resource for the mod you are suggesting that you could link to?
Reply 5 of 17, by tanasen
The seller of the VSTA couldn't guarrantee of its working condition so I opted for the 775i65G. I have a PentiumD 820 for now. If everything works ok I'll order the Pentium E5800. Also my RAM kit is a Samsung 2x1GB DDR 400MHz cl3. Will I need a cl2.5 kit ?
Reply 6 of 17, by agent_x007
Biggest problem with ASRock AGP/PCIe boards on Quads is massive Vdroop/no LLC, and FSB limitations.
256MHz (real clock), is usually required for full stability (stock) and -0,1V Vcore drop under load doesn't help OC'ing.
As for 775i65... I own 3.0 version.
354.97 KiB
Reply 7 of 17, by tanasen
Update on this thread. Over the past 2 weeks I've built a system with the 775i65G R2.03. I'm still waiting for a Pentium E5800, but for now I use a Pentium D 915. Sadly my X-Fi Platinum died and I installed an Audigy2 value I had lying around. I've updated to the latest v3.30 bios installed the OS (WinXP SP3) on a 32GB SSD and atm I've added an 80GB IDE WD drive, along with an IDE DVD-RW drive. Gaming performance is as expected and even the Pentium D is a significant upgrade over the Pentium 4. The problem is that boot times are very slow. It takes 10 seconds to give signal and another one and a half minute to load to Windows. I've conluded that it is not efficient to run both SATA and IDE drives at the same time. Has anyone any experience with this problem? I'm considering dumping the SATA SSD and go all IDE (since I don't have a sata DVD drive atm).
Reply 8 of 17, by Imperator
agent_x007 wrote on 2020-03-05, 17:06:
Biggest problem with ASRock AGP/PCIe boards on Quads is massive Vdroop/no LLC, and FSB limitations. 256MHz (real clock), is usua […]
Hello.
I own 2x systems based on ASrock 775i65G one of them is rev 2.03 and one rev 3.0, both with ATI HD 3850 AGP.
Both systems have Quad Core Intel. The one with 2.03 have QX 6700 and the one with rev 3.0 have Q6700.
After i read the info you provided i noticed that indeed the VRM's are a bit hot, but i didn't had any problems until now.
Should i pay attention on something in particular ?
PC no1: - Intel STL2 G7ESZ Dual Socket 370 Motherboard + 2 x Pentium III 1Gz CPU + 4 x 1 Gb RAM
PC no2: - ECS K7VTA3 Socket 462 + Athlon XP 3000 + 1Gb RAM + 3dfx VooDoo 5 5500 AGP 64MB
PC no3: - ASrock 775i65G v2.03 + Intel QX6800 + 2GBRAM + ATI HD3850
Reply 9 of 17, by swaaye
I used to have a 775i65G (R2.0 I think). It worked well. I preferred to use a 800 MT/s CPU in it though because with a 1066 MT/s processor the POST initialization time was dramatically longer. I never tried a quad.
Reply 10 of 17, by Imperator
Yes, i can confirm that the POST initialization take ....a while. But It doesn't bother me. I would like to have as many info about the system other forum members used to , or still have.
Reply 11 of 17, by agent_x007
Imperator wrote on 2024-03-14, 16:58:
Hello. I own 2x systems based on ASrock 775i65G one of them is rev 2.03 and one rev 3.0, both with ATI HD 3850 AGP. Both systems […]
Hello.
Unless you OC, both of those don't apply to your use case.
Side note : Vdroop of -0.1V should be considered undervolting.
It's very good for your cooling, power bill and VRM/capacitor longevity (on stock settings).
Reply 12 of 17, by Imperator
I would be grateful if you would be so kind and share with us your settings to your magnificent system.
I bought my systems after i saw your system.
Of course the fine tuning you've made is the most important, so please share all the info you can with us.
Reply 13 of 17, by Imperator
I saw that you use a QX6850. You modded the BIOS or it was accepted in the original BIOS ?
I ask you that because in my case, i use a QX6700 and the results are far from yours.
And of course if you would be so kind and share some pictures with your setting from BIOS would be nice.
Reply 14 of 17, by Roman555
Imperator, I've read somewhere that a bios of the 775i65g rev3 supports the rev2.03 one and newer cpu-s better then original. I've got this old revision mainboard but I haven't tried to flash the newer bios. Maybe someone already did it and will confirm it here.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 15 of 17, by Imperator
In my case i own both revisions. I have 2.03 and 3.0
I am interested if he put in slot just like that or he did an update previously.
Anyway i ordered already a QX6850 from China.
I will test it in both motherboards.
I also ordered some coolers for VRM, just in case.
Reply 16 of 17, by Imperator
Good morning
@agent_x007 - i would like to ask you to be so kind and to share with us your setting for ASrock 775i65G system.
Most of all, you already made some tests, so for the rest of us would be a huge leap forward.
Thanks mate.
Reply 17 of 17, by agent_x007
Well, I don't have BIOS setting saved (and system itself was assembled just for testing - it's in parts currently). Regardless, you have most important things I ran in screenshot I provided (FSB, DRAM, timings, AGP speed [SBA]). BIOS I used is the official one.
Still, keep in mind my HD 3850 was OC'ed model, so you probably won't reach my results on "stock" model.
Some more results (E7500 vs. E6600k) :
355.36 KiB
361.98 KiB
