Reply 400 of 1134, by CoffeeOne
red-ray wrote on 2020-03-08, 16:14:
OK and it's much as I expected. I suspect the HP software was active when you did this and if the HP software is inactive is the […]
CoffeeOne wrote on 2020-03-08, 14:49:
OK, kernel logging was simply disabled, so I had to click on the icon, that was all that was missing.
OK and it's much as I expected. I suspect the HP software was active when you did this and if the HP software is inactive is the retry rate lower?
file.php?id=78525
  1. When act starts with 3x this is some other entity reading the DIMM temperature and the first 4 are when SIV is reading the SPD data.
  2. When act starts with E8 this is some other entity switching the PCA9544 mux
  3. When act starts with C8 this is some other entity accessing salve 0x60 memory buffer
  4. When act starts with C9 this is some other entity accessing salve 0x61 memory buffer
It would be interesting to get a driver log when all the HP software is inactive to see if any of the above go away.
I am also wondering if the HP software uses any locks. From Menu->Windows->Processes Right/Click on the PID button and select Locks to find out. Attached is what I just got for SIV64X so you know what to expect.
Hello,
I made some screenshots while all HP services were running:
HP service cisserv -> locks
The attachment cissesrv-locks.png is no longer available
HP service fio-agent -> locks
The attachment fio-agent-locks.png is no longer available
HP service fio-msrv -> locks
The attachment fio-msrv-locks.png is no longer available
HP service ProliantMonitor -> locks
The attachment proliant-monitor-locks.png is no longer available
and last but not least SIV -> locks
The attachment siv-locks.png is no longer available
Reply 401 of 1134, by CoffeeOne
2 more screenshots:
The first (also with all HP services enabled: "Lock Handle". It was not requested by you, but anyway ....
The attachment lock-handle.png is no longer available
And the second screenshot of DebugView: I ran SIV with your command, but before I disabled the 4 HP service:
The attachment debug-serv-disabled.png is no longer available
Reply 402 of 1134, by red-ray
CoffeeOne wrote on 2020-03-08, 19:07:
And the second screenshot of DebugView: I ran SIV with your command, but before I disabled the 4 HP services
Thank you, I was hoping that the HP services might use a different lock to interlock SMBus success, but they do not seem to.
There are still collisions with all the services stopped and I am running out of ideas as to what could be doing this and wondering if it might be the HP ProLiant iLO 3 Management Controllers. I guess these are built into the motherboard, are they? Is there a BIOS setup option to disable them?
Update: I wonder if it's the Microsoft Generic IPMI Compliant Device, can this be disabled in the BIOS and if not do the retries stop when you use Device Manager to disable the device?
Reply 403 of 1134, by mastergamma12
Hello
Is it possible if you could add in a vendor logo for BFG cards.
Reason: Restoring revision 172925
Reply 404 of 1134, by red-ray
mastergamma12 wrote on 2020-03-10, 07:49:
Yes, I could add the BFG logo if I knew the BFG vendor ID, but there seem to be two of them. I have 19F1=BFG Tech + 00F5=BFG Technologies in PCIDEVS.txt and am unsure which to use.
Please post Menu->Machine->GPU Info and [ PCI Bus ] so I can be sure I use the correct one and it would also be good if you posted the logo you feel I should use.
Edit: I guessed at 19F1, how does the attached SIV32L 5.47 Logo-04 test SIV look? If the logo is not on [ GPU Info ] also check the [ PCI Bus ] details panel, probably [ n - 00 - 0 ].
Reply 405 of 1134, by mastergamma12
red-ray wrote on 2020-03-10, 08:32:
Yes, I could add the BFG logo if I knew the BFG vendor ID, but there seem to be two of them. I have 19F1=BFG Tech + 00F5=BFG Tec […]
That did the trick.
Thanks.
Oh and here's 2 screenshots
Reason: Restoring revision 172926
Reply 406 of 1134, by red-ray
mastergamma12 wrote on 2020-03-10, 21:13:
That did the trick.
Good, I suspected it would. I wonder, why are you not using the latest GeForce 342.01 Driver?
I spotted the ITE IT8686 + IT8733 SIO voltages are slightly off. I can adjust this, but as there are two SIO sensors it would be easier if you posted or PMed me the two Menu->File->Save Local files so I can test the changes.
Update: I made some changes so please try the attached SIV32X 5.47 B450-04 test SIV, it should be better, but I will need the save files to further improve it.
I attached SIV32X.exe rather than SIV32L.exe as it's a Unicode rather than ASCII build so is a better choice for Windows XP and later.
Reply 407 of 1134, by mastergamma12
red-ray wrote on 2020-03-10, 22:10:
Good, I suspected it would. I wonder, why are you not using the latest GeForce 342.01 Driver? […]
That did the trick.
Using that driver because it was on a disc that went to a 660 ti I used to have and I figured it'd be better for compat purposes with older software.
Here's the two files you requested.
Reason: Restoring revision 172927
Reply 408 of 1134, by red-ray
mastergamma12 wrote on 2020-03-11, 21:55:
Thank you, when I checked and the test SIV was pretty close. All the voltages now look to be correct, but I have changed a couple of the names so once I release 5.47 Beta-04 update to that.
I would expect later NVidia drivers in general to work better then older ones, but I guess "if it's ain't broke don't fix it". In terms of SIV support in general the later the driver the more SIV will report as such NVAPI functions as NvAPI_GPU_GetRasterBackendCount(), which reports the number of ROPs, are only available in later drivers.
Update: I have just released SIV 5.47 Beta-04 and attached the .ZIPs to SIV support for 386/486/586 class + Alpha + PowerPC CPUs and 3dfx + XGI + old ATI + NVidia GPUs - Testing Help
Reply 409 of 1134, by TechieDude
Used the version you supplied in the PM. It actually worked. Here's the report:
EDIT: A few weird things I noticed: 1) The Pentium Overdrive MMX is a Tillamook (is it?). 2) It mentions 3DFX Voodooo 1 and an adaptec SCSI Card that weren't installed at the moment. The Voodoo was installed at some point, but it was already removed by the time I ran SIV. The SCSI card was at some point plugged in, but I didn't ever use it.
Reply 410 of 1134, by red-ray
TechieDude wrote on 2020-04-11, 00:38:
  1. The Pentium Overdrive MMX is a Tillamook (is it?)
  2. It mentions 3DFX Voodooo 1 and an adaptec SCSI Card that weren't installed at the moment. The Voodoo was installed at some point, but it was already removed by the time I ran SIV. The SCSI card was at some point plugged in, but I didn't ever use it.
Thank you for checking things out and the new 430FX code worked as I hoped.
  1. I can't remember why decided this as it's been like this since 29-Oct-2002, but after checking https://en.wikipedia.org/wiki/P5_(micro ... #Tillamook I think it should just be P55C so will adjust this for the next beta.
  2. Where does it mention this? At a guess it's on [PCI Dev] + [ALL Dev] as they list devices that have ever been installed, to get a list of the PCI devices that are currently present check [PCI Bus].
Reply 411 of 1134, by TechieDude
Ah, that explains it.
Reply 412 of 1134, by feipoa
red-ray> Do you maintain a database of systems tested that you wouldn't mind sharing with the forum? This way forum members could look in there and see what hardware is missing and decided to test it.
Reply 413 of 1134, by red-ray
feipoa wrote on 2020-04-12, 14:13:
No and even if I had it would not help. It's far less effort to run SIV and quickly look if the information SIV reports for your system is correct. Things to check are:
  1. Are the memory timings reported and correct (typically tCL+tRCD+tRP+tRAS+tRFC).
  2. Is the CPU information correct.
  3. Are all the GPUs reported and is the information correct.
  4. Are the SIO sensors reported with the correct values and appropriate names.
  5. Is the DIMM SPD reported (NT/2K/XP and later).
Reply 414 of 1134, by CoffeeOne
Hi Ray,
Boring Easter sunday 😁
OK, tried the latest beta of SIV with one of my HP DL585 G6.
I would say it's close to perfect, DIMM info is missing, because the SMBUS could not be read out. That was expected, I would say 😀
Main screen:
The attachment siv1.jpg is no longer available
Save local (2 files zipped together) attached
Reply 415 of 1134, by mastergamma12
So I came across something kinda weird but it triggered my OCD
So on older MSI board's in the machine tab, it shows the MSI logo
But on a newer board like the Z390 Ace, it doesn't show one.
Would it be possible to re implement that logo on the newer boards?
Reason: Restoring revision 172928
Reply 416 of 1134, by red-ray
mastergamma12 wrote on 2020-04-12, 19:51:
Thank you for your post , obviously yes and I wonder why it's not already there. At a guess it's down to MICRO-STAR vs. Micro-Star, either way the easy option is for you to post the two save files from the Z390 board so I can figure out why it's absent.
Reply 417 of 1134, by mastergamma12
red-ray wrote on 2020-04-12, 20:14:
Here's the files
Reason: Restoring revision 172929
Reply 418 of 1134, by red-ray
mastergamma12 wrote on 2020-04-12, 20:24:
At a guess it's down to MICRO-STAR vs. Micro-Star.
Here's the files
My guess was correct and the attached SIV64X 5.47 OCD-11 test SIV should have the Icon, does it please?
Reply 419 of 1134, by mastergamma12
red-ray wrote on 2020-04-12, 21:04:
Here's the files
Tested on both a X370 Xpower and the Z390 Ace.
Both work
Thanks again
Reason: Restoring revision 172930
