Reply 14520 of 31262, by bjwil1991
Man, sorry about the floppy drives. Where're you from, eh? I made a USB to PS/2 adapter one time and got 2 of the wires incorrect, and fortunately didn't break the mouse. After fixing the error, the mouse worked without issues. Going to solder the wires together and put some heat shrink tubing on the wires or electrical tape to prevent the wires from touching each other. I might make a PS/2 to serial adapter, but I have plenty of those (came with PS/2 Microsoft Mice in boxes) adapters.
Reply 14521 of 31262, by aha2940
bjwil1991 wrote on 2020-03-20, 00:09:
I'm from Colombia (Columbia?). I already bought another mouse to replace the fried one. They are like 6 bucks shipped around here.
Reply 14522 of 31262, by Horun
aha2940 wrote on 2020-03-19, 20:46:
Thanks for the information guys. Unfortunately it seems these drives are dead. i tried to format a diskette on both and none will format it, they complain about "Invalid media or track 0 bad - disk unusable". However, the disk is OK, as it works on two other floppy drives I have. Anyway, does anyone have a couple floppy drives for sale? around here they sell them like they are made of solid gold, 🤣.
Hmm have only had a few 1.44mb drives be dead from all my used drive purchases, given, etc. Most just keep working not matter what. My guess is the lot bad and is why was free. Shipping to SA is too expensive or would send you a good used working one free.
Reply 14523 of 31262, by assasincz
Few weeks ago, I found and ad for a random "PC board" which showed in some rather blurry pictures what I though is a 286/386 baby-AT mainboard, 8-bit ISA VGA and a 16-bit ISA HDD/FDD controller. For equivalent of 14 USD, I decided to investigate.
Picking up the package right before the pandemic broke out, I could see that it is a 286 system running AMD N80L286-16/S CPU. The closest fit to the mainboard is the MINI-AT286 (G2-206) and the GPU appeard to be very similar to this OTI-037 card, all in very nice condition!
Yesterday I decided to test it out. There was a barrel battery which surprisingly did not leak until now, but I desoldered it anyway and in its place put a coin cell battery holder for future LIR2032 3.6V. Nice fit.
I then tested it under power. After switching it on, immediately one of the four tantalum caps near the AT connector blew up - I kind of expected that.
I figured all of them are probably 10uF 16V, so I replaced them with some radial electrolytics I had on hand (3x 10uF 16V, 1x10uF 35V) and tried it again.
...and...success. I am going to have so much fun making a full build out of that...
The attachment 20200319_193219.jpg is no longer available
The attachment 20200319_183954.jpg is no longer available
The attachment 20200319_193257.jpg is no longer available
The attachment 20200319_193215.jpg is no longer available
The attachment 20200319_193237.jpg is no longer available
Reply 14524 of 31262, by CharlieFoxtrot
I installed P3 Coppermine 800/100 MHz and Leadtek GF2 GTS to my Slot 1 machine to give it a bit more oomph. I needed to fiddle little bit with the heatsink of the processor. It had these plastic attachment clips and one of them was slightly broken, which meant that there was practically zero pressure on the die. So, I used good old zip ties which secured the heatsink adequately and while I was at it, replaced old hard silicon paste with MX4. Then I booted the machine, set up the processor in the bios, installed drivers for the card and it works just fine!
This upgrade really shows how rapid the evolution was at that time. My period correct "1998" Slot 1 system with Celeron@450 and TNT+V2 was pretty much top notch in autumn 1998 and with my new configuration with GF2 GTS which was released approximately two years later, the gaming performance is pretty much 2,5 times better according to 3DMark99. That is simply a huge leap.
Reply 14525 of 31262, by derSammler
CharlieFoxtrot wrote on 2020-03-20, 08:34:
I don't see 2.5 better gaming performance as a huge leap for hardware that was released two years later. This is actually a difference you already had within the same family of graphics cards released at the same time, like between a GeForce2 MX and a GeForce2 Ti/Ultra.
The GF2 GTS is actually about 9 times faster than your TNT. The CPU you use is a huge bottleneck. CPU speed was already way beyond 1 GHz when the GF2 hit the market. You pretty much got 2.5 better gaming performance because that's exactly how much faster the CPU is. The graphics card doesn't even come to play here.
Reply 14526 of 31262, by brostenen
derSammler wrote on 2020-03-18, 18:20:
Not possible, because it has no hard drive. And it has no hard drive because it has no network adapter. 😉
It's a backup PS2 only anyway, the main one has everything and can use SMB, USB, HDD, and burned discs.
There are also the option, of converting the Ps2-DVD-Backup ISO to an DVD movie ISO, and then you can load it using eject button on the console. Works only with DVD backup's.
Reply 14527 of 31262, by CharlieFoxtrot
derSammler wrote on 2020-03-20, 08:52:
I agree as 3DMark score scaled almost 1:1 to CPU speed. I also tested GF2 GTS quickly with the celeron, and 3DM99 score went up only few hundred points, so it definitely is CPU limited.
Reply 14528 of 31262, by ShovelKnight
Fired up my Windows 98 PC to install unofficial patches for Planescape: Torment. I thought it didn't work at first, because the PST Fixpack would just hang with a message "Copying and patching 1 file..."
But then my wife called me to hold our cat while she was giving her an injection of painkillers (the cat had a surgery 2 days ago). When I returned, the patcher was busy replacing and patching game files. It turned out it took almost 20 minutes for a K6-II+ 550 MHz with 256 MB of RAM to open and parse the VAR.VAR file from Planescape: Torment. In total it took about 40 minutes to install the patch. The Unfinished Business pack and the Tweak Pack each took about 20 minutes to install.
So if you have faster Windows machines (I don't; my other computers are either Mac or Linux), it would be better to patch the game before transferring it over to the period-appropriate hardware...
Reply 14529 of 31262, by brostenen
Installing Sparkle-Linux on an old IBM Thinkpad R52. The machine have 1 gigabyte of memory. Sparkle-Linux can be installed on a machines with no more than 256mb Ram and with a GUI. The command line version only need 128mb. And it can run on Pentium-M processors. The best thing, is that Sparkle-Linux is Debian based. The machine is for my daughter, to explore and get used to Linux.
Reply 14530 of 31262, by LewisRaz
Spent way too many hours and 3 different set ups trying to get this mouse to work. No luck.
Seen a few posts on here about mice with this switch but I just cannot get any joy from it. Annoying as my current project only has serial for a mouse.
My retro pc youtube channel
Twitter
Reply 14531 of 31262, by derSammler
What mouse drivers did you try? 3 buttons mean it's a Mouse Systems mouse, so you can't use a driver that supports Microsoft mice only.
The switch *may* allow selecting between Mouse Systems and Microsoft, but I wouldn't bet on it.
Reply 14532 of 31262, by bjwil1991
CuteMouse has a flag for Mouse System mice (ctmouse /M), but, I haven't attempted that before with a 3 button mouse on a serial port. Normally, the toggle switch is for PS/2 and AT (serial with the PS/2 to Serial adapter installed). I have a mouse that has that style switch.
Reply 14533 of 31262, by LewisRaz
derSammler wrote on 2020-03-21, 18:51:
The switch has 2 options "PC" or "MS"
I tried the "standard serial mouse" as well as "microsoft serial mouse" that are part of windows 95.
With both switch settings I cannot get anything from it.
Twitter
Reply 14534 of 31262, by bjwil1991
There is a driverset in the Windows 95 CD that contains the Mouse Systems driver. I can upload the drivers here for you in case you don't have the CD. Here you go.
The attachment mousesys.zip is no longer available
Reply 14535 of 31262, by derSammler
LewisRaz wrote on 2020-03-21, 19:01:
That's why I said it may switch between Microsoft and Mouse Systems. I don't know what "PC" is supposed to mean, and "MS" can be either of the two. One setting is Mouse Systems for sure.
Reply 14536 of 31262, by bjwil1991
MS is Mouse Systems, and PC is Serial (PC AT), I believe. I'll test that theory on my 486 with the drivers installed and see what happens.
Reply 14537 of 31262, by derSammler
Mouse Systems is serial as well. 😉 Unlike serial mice following the Microsoft standard, Mouse Systems could support three buttons instead of two. But both standards used RS-232.
Reply 14538 of 31262, by LewisRaz
Installing the mouse systems driver gets me a mouse in device manager that does not have a !
Still no life tho. Guess the mouse could actually be dead.
Twitter
Reply 14539 of 31262, by bjwil1991
If you have a serial to PS/2 adapter, it'll work. Mine has a PS/2 header on it and doesn't work with my PS/2 to Serial adapter (gets detected, but not moving, possibly because it needs a serial header on it, will test that theory), except it works using the PS/2 port in both DOS and Windows 95. I even checked the switch continuity and it all passes. Is yours a PS/2 mouse?
