Reply 200 of 805, by CoffeeOne
Mumak wrote on 2020-03-03, 13:14:Meanwhile I have 2 new builds, would be great if you could test both and provide results as I'm not sure which method will work […]
CoffeeOne wrote on 2020-03-02, 20:14:Yes: Seems to be nearly as good as 4095 :D hwinfo-5098-main.jpg There are special characters in the DIMM names, that's new. […]
Mumak wrote on 2020-03-02, 15:18:Ready for yet another test? 😉 This will be a special one - attempting to access the 7500 Scalable Memory Buffers for the first time.
Since I haven't tried this before, I don't know if it will work. But if it does, we should be able to read additional memory parameters including the Memory Buffer temperatures.
Here the test build: www.hwinfo.com/beta/hwi64_623_4098.zipYes:
Seems to be nearly as good as 4095 😁
There are special characters in the DIMM names, that's new.But joke aside, what should be shown additionally?
Meanwhile I have 2 new builds, would be great if you could test both and provide results as I'm not sure which method will work better. Here they are:
- www.hwinfo.com/beta/hwi64_623_4099.zip
- www.hwinfo.com/beta/hwi64_623_4100.zip
Sorry for so many requests, but it's difficult to develop/test such system remotely. We (I and Ray) were already considering buying such machine, but none of us is yet keen on spending several hundreds of EUR just for a couple of days of testing...
Just one more question (also to Ray 😀 )
Do you plan to show if "hemisphere mode" is enabled, too?
https://support.hpe.com/hpesc/public/docDispl … mr_na-c02283239
