Finally finished the Gotek slimline drive project for the oldschool thinkpad (had to hack a Gotek SFR1M44-DU26 with the 26 pin FFC26 ribbon cable to replace the TEAC FD05 inside).
There were some discrepancies between the standard 34 pin and the 26 pin version (FFC26) that had to be reconciled.
Took a while, but it's finally done complete with an LCD screen (I'll likely need to add something on it to fix the faint display output)
How faint? It's pretty faint.
What's it for?
I call it "project warp" - trying to get Ono-Sendai (my 166MHz Thinkpad 560E) to do OS/2 Warp 3 or 4. Warp 3...didn't work well so far.
That one is still in progress - the OS/2 Warp 4 diskset is 111 disks in total, and even with a Gotek it's still rather time consuming.
Also had to troubleshoot the power plane on my t5720 thin client...for some reason the PCI slot will not work with my nVidia GF6200 nor my AOpen YMF744 Cobra (as in, the machine fails to power up with a card inside), but seems to work fine with an Intel Pro/100 and a Promise TX4 based PATA controller. I suspect I'll need to replace at least one bulged capacitor.
