Reply 14780 of 30907, by ragefury32
Finally got some time to mess with the iSiS Imagestream TransPort router - had to finagle up a USB connector and connect a Geforce 6200 so I can have VGA output. Still, not too bad. The device has a 10 pin VGA header but I'll need to order a PC104 VGA cable from overseas to use the onboard Cyberblade i1.
Eh, back to the busted t5720 board. Looks like something is very wrong with the power plane and possibly other problems - the SiS Mirage onboard graphics is conflicting with the ACPI in every OS I tried it on, the VT6107 NIC is showing up as all fs on the BIOS system info screen, and is failing to work. Spent half an evening looking for compatible caps on Digikey, and ordered a batch of them for potential recapping. See if you can spot the bad/bulging cap on the board.
