First post, by PC-Engineer
- Member
After long research i could obtain a 8 Bit I/O Card with two internal serial ports and one inter parallel port.
I had the hope to find the Jumper Config on Stason, but without luck.
Maybe someone can help out with some hints.
Big IRQ Jumperblock in the middle is clear (from top to bottom): internal printer;  external printer; COM2; COM1
Block on left side, JP 1-4: maybe activation (pos 2/3)/ deactivation (pos 1/2) of COM1-2 & parallel 1-2
Small Block in the middle, JP5/6/9: hmmmmm
Would be glad, if someone can support.
Thanks and best regards
Lutz
