HWiNFO for DOS resurrected !
Reply 440 of 958, by hasat
OK, I'll try it, but not until Friday or the weekend.
Reply 441 of 958, by Mumak
Here a new build to fix an issue with identifying of some Award BIOS based mainboards.
[build pulled, newer available]
Reply 442 of 958, by feipoa
Attached are the reports for my Gateway 2000 system - 1 GHz Orion slot A.
It says my Matrox G400 max is running at AGP 1x. Is this correct? The G400 runs at 2x or 4x. I wonder if the Gateway BIOS is reducing the rate for some reason?
Where do I view the UDMA transfer rate that the ATAPI DVD-ROM drive is using?
Reply 443 of 958, by Mumak
feipoa wrote on 2020-05-07, 11:50:
Please run the attached tool and send me the files it produces. I will then check if the AGP rate reported is correct.
The attachment GETPCI.EXE is no longer available
Reply 444 of 958, by feipoa
Attached.
Reply 445 of 958, by hasat
Mumak wrote on 2020-05-06, 09:47:
hasat wrote on 2020-05-06, 09:38:
Mumak wrote on 2020-04-29, 14:47:
That looks more like the KBC check is the problem here. But also wondering why the FDC37C663 wasn't detected, in the build above I added detection per its datasheet.
Hi Martin,
I am sorry for late answer, 30.4. you sent me PM about better detection LAN adapter and SIO in my HP Vectra. I can't sent you PM, because i am newly registered user here. If it is still actual, yes you can send me new version of HWINFO with improvements in detection and i test it for you.
Yes, I'm still interested. Please use the version attached here: Re: HWiNFO support of vintage hardware
New testing on my HP Vectra. HWINFO still freeze on peripherals screen. With EMM386 error "Fatal error, cannot continue" appears and the computer hangs, wthout EMM386 no error, but still computer hangs with some garbage text in lower right corner. In archive are attached log and dbg files and also screenshot when computer hangs in both cases.
Reply 446 of 958, by Mumak
feipoa wrote on 2020-05-08, 09:30:
Attached.
So it's as HWiNFO says - the Matrox supports both AGP 1X and 2X, but it's currently running in 1X mode only.
Reply 447 of 958, by Mumak
hasat wrote on 2020-05-08, 11:06:
Hi Martin,
Thanks. Yet again nothing works as described in the datasheet. The AMD PCnet should return 10h as HardwareID, but it's 0 here. The SIO should return an ID, but it doesn't.. Oh, well...
Reply 448 of 958, by hasat
Like someone here said: how older and easier device is, more work with it is. Thank you for your work. I think it's time to move to next retro hardware. Now i start playing with a little bit newer hardware (socket 7) and here HWINFO running without computer hangs. I found two errors: incorrectly detected graphic card (integrated in SiS 5598 chipset) and some weird text in VBE 2.0 revision string. It's not visible in complete report, but only in report created in video section of HWINFO (F2 key). Reports attached.
But if you want make some research on problems on my HP Vectra, i'm ready.
Reply 449 of 958, by Mumak
hasat wrote on 2020-05-08, 16:31:
Thanks. Here a new build attached.
This should recognize the graphics adapter as SiS 86C201 and hopefully fix the other bug too.
Would be great if you could run it on the HP Vectra too. It will most probably work same as before (no need to make tests with and w/o EMM) , but I've added more information into the DBG file that could tell me how to fix the SIO hang.
Reply 450 of 958, by feipoa
Mumak wrote on 2020-05-08, 11:08:
Attached.
Odd. Do some motherboards leave the AGP set at 1x in DOS then switch to 2x in Windows, or perhaps switch to 2x when 3D acceleration is used?
Reply 451 of 958, by Mumak
feipoa wrote on 2020-05-09, 02:18:
Attached.
Quite unlikely that the BIOS would treat this different. But you can always check what mode is active in Windows using HWiNFO32 😉
Reply 452 of 958, by hasat
Mumak wrote on 2020-05-08, 18:06:
Thanks. Here a new build attached. This should recognize the graphics adapter as SiS 86C201 and hopefully fix the other bug too. […]
HWINF610.ZIP
Here is new test on ASUS SP97-V motherboard with integrated video card in SiS chipset: name is OK, but reported video memory is wrong - HWINFO still reporting 2048 kB memory regardless of what is set in BIOS (1 MB, 2 MB or 4 MB).
VBE2 revision string is also still wrong: i discovered new thing, text in this field is changing depending on what is loaded in memory (for example i run HWINFO from DOS prompt and from Volkov Commander). Two examples are in video.log file. Very interesting bug! 😁
Reply 453 of 958, by Laaca
Nice to see the project resurrected. I tried it on my Lenovo Legion notebook under FreeDOS. It is a little bit unstable but in minimal setup with HIMEMX only loaded it works.
But I am disappointed that it can't properly detect my 16GB of RAM. It reports only 2GB. I understand that such new machines aren't the main targets for HWINFO but such basic functionality should work, IMO.
And also is a pity that my harddisk (M2/PCI espress) is not detected. I know, HWINFO searchs directly the hardware and does not ask the BIOS but anyway, this is also kind of basic functionality and it should appear somewhere.
For example, I added a screenshot from Necromancer's DOS Navigator. It is not a hardware detection program but filemanager however both mentioned topics does better than HWINFO does.
Reply 454 of 958, by Mumak
hasat wrote on 2020-05-09, 13:14:
HWINF610.ZIP
Thanks. I've got an update for the VBE revision issue, but don't know how else to report the shared video memory size. Will post once you provide new data for the HP Vectra.
Reply 455 of 958, by feipoa
See photo for error.
The attachment Gateway2000_Kadoka_1Ghz_Orion_with_ATI_8500DV.jpg is no longer available
Reply 456 of 958, by Mumak
feipoa wrote on 2020-05-10, 12:16:
It might be because AGP mode is currently disabled, so it falls back to PCI.
I'd need to see files generated by GETPCI.EXE
Reply 457 of 958, by hasat
New test from HP Vectra.
Reply 458 of 958, by Mumak
hasat wrote on 2020-05-10, 13:17:
Thanks. That's weird as HWiNFO tests for the FDC37C663 SIO exactly per the datasheet, but it doesn't return the expected ID..
I will post a new build with some improvements for the VBE and also add reporting of AGP rate supported later today.
Reply 459 of 958, by Mumak
Here the new build. I don't know how to solve the SIO crash on HP Vectra as it's not behaving according to datasheet.
