First post, by delinthe
Got this in a few days ago. Needless to say Fedex did a bang up job. The seller was kind enough to refund the purchase and told me to keep it and salvage whatever I can from it.
I can fix most things... but this might be a lost cause. Fairly certain the PCB pieces are from the CRT control board. That's a pretty simple circuit but CRTs scare me so i'm hesitant to try building a replacement. I'm pretty hesitant to even plug the thing in lest it catch on fire or blow up the tube. What do you guys think?
Hoping to save the soundblaster 16, and CPU at the very least.
Reply 1 of 6, by brian105
Oh lordy, that's abuse. Poor Compaq. Hope you can salvage at least something. The hard drive and mobo are probably damaged past repair, sadly. CRTs 500% bagel.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 2 of 6, by delinthe
So luckily it wasn't coming with a hard drive or that would definitely be hosed. A more thorough inspection shows that the control board for the CRT has a Pot basically snapped in half having dropped the entire trim knob. I also noticed that the power button mechanism is physically jammed and won't depress. The motherboard and sound blaster however don't show any obvious signs of physical damage.
I think there's a good possibility the system itself might be salvageable. If that's the case the biggest problem here is that the motherboard connects to the monitor and power supply via a proprietary card edge connector. Video is no problem I can always just throw a video card in to get the output to another display. Power would be a little more tricky. I'd have to wire up an edge connector, or bypass it and feed power directly into the board nearby.
Of course the entire point of the Presario 400 series is the really cool all in one form factor. Maybe if i'm adventurous I'll try putting this thing back together and firing it up just to see what happens.
Reply 3 of 6, by brian105
You should definitely report this to Fedex, this isn't something normal.
Reply 4 of 6, by derSammler
brian105 wrote on 2020-05-16, 05:44:
They won't care, because it's not their fault. You can clearly see on the third picture that the packaging was completely insufficient for shipping such a thing. Some bubble wrap and almost no clearance between the item and the box won't protect a heavy CRT+PC with an old, brittle plastic casing. It's always easy to blame the shipping company, but that packaging does not even adhere to the rules for packing non-fragile stuff.
Reply 5 of 6, by delinthe
I'll agree it should have been double boxed. The seller is dealing with Fedex over the damage trying to set up a claim. In the meantime I was refunded the purchase price. It's sad because these systems don't come up for sale too often, and when they do they're normally pretty expensive (300-500 + shipping). If nothing else I got a most likely working sound blaster pro 2, and a 486 sx25.
Reply 6 of 6, by EvieSigma
I had the same thing happen to me 4 years ago with a Macintosh Performa 580 for the same reason (severely insufficient packaging). I salvaged the drives and motherboard from it and scrapped the rest...good thing the 580 wasn't one of the models with a Trinitron CRT.
