First post, by Jonnyboy161
Specs:
Motherboard: RedFox AGP-ALi (Baby AT)
Northbridge: M1542 A1
Southbridge: M1543C B1
CPU: AMD K6-2 475MHz running at 500MHz (i've tried setting setting to 450MHz) 2.2v
VIDEO: Asus FX 5200 AGP
RAM: 2x128MB PC 133(Passed multiple memtests)
SOUND: Audigy Zs 2
HDD: Old 30GB WD IDE drive (I've also tried another 40GB WD IDE drive)
First of all I can't seem to find the chipset drivers for this board. I attempted to install the "ALi and ULi Integrated Chipset Installer V2.20 Final" as that is the only one that seemed close to what I needed, but it fails install. It says the program performed an illegal operation and will be shut down. (SETUP cased an invalid page fault in module KERNAL.32.DLL at 0167:bff886df). Win98 preinstalls chipset drivers for the M1541 which from what I understand is the ATX chipset.
I found and installed sound drivers with no issues. I tried both v71.84 and v56.64 drivers for the FX 5200, and both installed fine.
System is mostly stable in Win98 with zero crashes when not in a game(I even tried WinXP for fun and it was very slow of course, but it was stable). It can vary from anywhere from a couple mins to an hour before it freezes up in Quake II.
When I say it freezes it just locks up with quake frozen with the music still going for a couple mins before it goes silent leaving me to simply kill the power. It has blue screened on me a couple of times outside of games saying "A fatal exception 0E has occurred at 0028:C004573E in VXD VFAT(01) + 0003ED2. "
The behavior of this system leads me to believe that either that chipset driver, or the graphics card are causing the crashing. I have heard that SS7 boards can be picky about AGP cards.
I'm new to installing Win98 so I could use help. I've included pictures of a couple of the error messages and of the motherboard. Thanks in advance.
