MR-BIOS for C&T PEAK/DM
First post, by Anonymous Coward
A few months ago, a huge cache of MR-BIOS ROM images was discovered:
How about a MR-BIOS ROM file repository?
Among them were many versions of MR-BIOS for the C&T PEAK/DM chipset. I have a 386 board based on this chipset. It's a Silicon Star/Abit FU340. I tried every single PEAK/DM MR-BIOS, and not a single one could detect the external cache. I really don't understand, because FU340 is a very common board with this chipset, so you'd think it would easily work. Is there anyone else on here with a 386 board with PEAK/DM that can try it out?
My board uses the B1 stepping chipset. I was testing with a 386DX-40, 8MB DRAM and 256kb cache.
Reply 1 of 22, by pshipkov
I have the same motherboard with the same problem.
Also, there are at least two more reports out there about similar mobos and chipset.
All these early, wide format, 386 mobos are slow and clunky.
retro bits and bytes
Reply 2 of 22, by Anonymous Coward
I think you mean long, not wide. I actually disagree about all of them being slow and clunky. Some of the fastest ones are actually full length baby AT. AMI Mark V Baby Screamer being one. There's also a Chaintech board with SiS Rabbit chipset that's quite speedy. The FU340 is not exactly a slouch either. It benchmarks in DOOM pretty well, and it has impressive memory throughput.
Did you start any threads about your experience with the board?
Reply 4 of 22, by Paar
I have managed to test one of the MR-BIOSes that were available. My motherboard has 64kB cache installed and it showed fine on BIOS screen (used V051B321 file). I'm attaching memory results from Speedsys too.
I have dumped my original AMI BIOS that came with my motherboad and it's called FU3-V8 PAGE MODE BIOS. I've compared it to other BIOS files that are available on the internet and it seems different. I'm attaching it too, maybe you'll find it useful.
    ami_peakdm_page_bios.zip
    38.04 KiB
    58 downloads
    AMI BIOS for Peak/DM motherboard - PAGE BIOS
Reply 5 of 22, by evasive
30-0200-D01247-00101111-050591-PEAKDM_B
D01247 -> 1247 = Abit
if you have a FU3 V1 board, please make a picture for the wiki
https://www.vogonswiki.com/index.php/Abit_FU3_Version_1
FU3 V2 board:
https://www.vogonswiki.com/index.php/Abit_FU3_Version_2
Reply 7 of 22, by Deksor
This FU3 V1/V2 thing may be different.
See, the "FU3 V1" is apparently a 386SX. I doubt a v2 would jump right to 386DX
This seems to be based on TH99. On TH99 there is a "FU3", but no "V1". Only this https://stason.org/TULARC/pc/motherboards/A/A … ON-386-FU3.html
Meanwhile, there's a version 2 here https://stason.org/TULARC/pc/motherboards/A/A … -FU3-VER-2.html
But then again, there's a Abit FU325/FU333/FU340 : https://stason.org/TULARC/pc/motherboards/A/A … U333-FU340.html
And the "FU3 ver2" and "FU325/FU333/FU340" look identical.
Why is that ?
Well since I worked with TH99/Microhouse Technical Library for over a year now, I noticed that many mistakes were made, and also I recently figured out something new when I wanted to add a 486 mobo I had.
This is the 486 mobo I had, a Gemlight GMB-486SG rev 2.2.
1.73 MiB
But looking at TH99, there's only a version "6.02" https://stason.org/TULARC/pc/motherboards/G/G … G-VER-6-02.html
Now that's strange, because I haven't seen a motherboard having over SIX revisions and even by looking online I could only find boards with similar rev as mine like this one : https://allegro.pl/oferta/gemlight-gmb-486sg- … -vlb-7835075169
But then, after seeing the manual I figured it out : http://minuszerodegrees.net/manuals/Gemlight/ … tion%206.03.pdf
manual wrote:
GMB-486SG High Performance 486VLB Motherboard User’s Manual For GMB-486sg v2 […]
GMB-486SG
High Performance
486VLB
Motherboard
User’s Manual
For
GMB-486sg v2
Manual Edition 6.03
Now THAT looks close to what's in MTL/TH99 ! But it's the manual's revision, not the motherboard's !
But since they probably used manuals to create Microhouse Technical Library (I doubt they went and retro-engineered nearly 6000 motherboards), they probably made other mistakes of that kind.
TL;DR this "FU3 rev1" thing is probably a non issue and just a manual revision, not a motherboard revision.
Reply 8 of 22, by Anonymous Coward
Please post a high resolution picture of your FU3 motherboard.
I should really try setting my external cache as 64kb to see if the BIOS will pick it up. I remember Feipoa had issues getting 256kb cache to work on his FU340 with AMI BIOS.
Reply 9 of 22, by evasive
That was used in most of the machines of a client I was working at back then. I think I have all the manual revisions. I may even have noted what manual goes with what board revision.
Reply 11 of 22, by Anonymous Coward
Your board seems basically identical to mine, and has the same B1 stepping chipset.
Reply 13 of 22, by Joyride
Hi! Maybe i can help you.
Im working on a Chips PEAK/DMmotherboard right now that looks like yours.
I cant get it to boot. I have tried flashing it with AMI bios but then it wont even turn on.
Anyway i have saved my BIOS if you would like to try it out.
Here is a picture of the board and the attached bios:
Reply 14 of 22, by Joyride
Paar wrote on 2020-05-31, 18:25:
I have managed to test one of the MR-BIOSes that were available. My motherboard has 64kB cache installed and it showed fine on B […]
Hi! Is it possible for you to share the MR BIOS V051B321 file? I cant find it anywhere.
Best regards /Rickard
Reply 17 of 22, by Anonymous Coward
Did you confirm the external cache is functional?
Reply 18 of 22, by feipoa
Yeah, 64K has never been an issue on this chipset. Try 256K and see if a) it is detected, b) it actually works by increasing benchmark scores.
Reply 19 of 22, by Anonymous Coward
256kb works fine on my board with AMIBIOS and C&T BIOS. But, it is not detected with MR-BIOS. I can't remember if I tried 64kb setting with MR, but I am pretty sure I did.
