First post, by jasa1063
- Oldbie
I just wanted to share my experience with what I found to be a decent AGP card on the two Super 7 motherboards that I have. Now if you have a Voodoo 3 card laying around that should be your first choice, otherwise purchasing one will cost you around the $100 mark as a starting point on eBay. I finally decided to go with the Matrox G400 Max. These cards can be found for $25-$30 on eBay if you shop right. I got mine for $30, which is a decent price. I have had no issues using the cards in both my Shuttle HOT-597 (VIA MVP3) and MSI MS-5169 (Ali Aladdin V) systems. The only thing on the HOT-597 is I had to run the AGP driver at 1x speed. The MS-5169 can run at 2x with no issues. The Maxtox G400 also comes in a non Max version, but that runs a lower clock speed, so go with the Max instead. Also avoid the Matrox G450 and G550 boards. The G450 performance is bad no matter which way you slice it and the G550 while having a bit higher OPENGL performance, has less than stellar Direct 3D performance. I threw in the towel on trying to get NVidia GeForce AGP cards working. Just when I thought things were Ok, something else would go wrong. NVidia drivers on Windows 9x are problematic in general. I even had issues on my PIII which is an Intel SE440BX-2 motherboard. I ended up putting my Voodoo 3 in that system. Matrox may not be the first video card that comes to mind for a retro build, but the G400 Max should be one to at least consider.
