First post, by cyclone3d
- l33t++
I am looking to build a maxed out 286 setup. Why? Because I can.
I also have a 286-486 upgrade but I want to get this set up with a 286 CPU before playing with the 486 upgrade.
Anyway, I already have 2x 286 motherboards. One with a 10Mhz and the other with a 12Mhz CPU.
I have a couple Harris 286 25Mhz CPUs and an Intel 287XL FPU on the way.
I have seen some posts about trying to get one running with a 25Mhz CPU and not being able to so I would like some guidance from anybody that has experience with this type of setup.
My end goal is to be able to be able to have a 286 setup that I can have and easy-ish way to adjust the CPU clock speed.
The simplest way I think would be to set up a small breadboard with multiple crystals and then have a jumper block to be able to switch between the crystals.
I've also seen that there are programmable crystals that can be set to go from as low as 900Khz to as high as 200Mhz. I haven't looked into the datasheets or anything but something like that would be super interesting to use if the speed can be reprogrammed easily/quickly. Anybody have any experience with these?
