Reply 35200 of 53282, by pan069
appiah4 wrote on 2020-07-21, 11:17:
Well, I've cleaned the board (and the socket) as best I could. There were also some bent legs on the northbridge that I straigh […]
Well, I've cleaned the board (and the socket) as best I could. There were also some bent legs on the northbridge that I straightened.
Disassembling the socket didn't work too well, I managed to remove the lever but removing the top part was not possible. There are some socket/tabs that hold it down and the socket plastic is too brittle to actually flex enough to remove the top without cracking it, so I gave up. The hole around the scorched plastic is wide, I'm pretty sure this is due to an overheating pin that scorched the socket plastic and 90% confident the socket pin should work fine. I will give it a try tonight and see how that works out.
I have the same board, newer revision though. I was lucky, I found it new in box a little over a year ago. I'm using it in my 486DX4-100 build. It didn't came with a PS/2 mouse bracket though but I got one of those generic Startech PS/2 mouse headers, I just need to change the motherboard connector on it.
Reply 35201 of 53282, by bjwil1991
wiretap wrote on 2020-07-21, 20:30:
Seller said it powered on and started up for a minute, then downpowered and wouldn't turn back on. I'll take on the challenge. H […]
Seller said it powered on and started up for a minute, then downpowered and wouldn't turn back on. I'll take on the challenge. Hopefully it is just the power supply.
Or the Varta Ni-Leakium battery. Those are notorious.
Reply 35202 of 53282, by bearking
I traded today a few of my spare CPUs for these, also paid like 22 euros extra. Made the deal with a local scrapper, really nice guy. I hope he will become my "gold mine" of old stuff...
Unfortunately, the K6-2+ 550ACZ is not working, tested it on an ASUS P5A rev 1.04 with the latest beta BIOS 🙁
The P60 is an SX835, it should have the FDIV bug...
Reply 35203 of 53282, by bjwil1991
The CPU has the FDIV bug
Ironically, the Pentium OverDrives for the 486 machines had no bugs and the 386 CPUs all have the POPAD bugs, even the double-sigma ΣΣ CPUs.
Reply 35204 of 53282, by wiretap
bjwil1991 wrote on 2020-07-21, 21:33:
True, hopefully not. If that's the case, I'll just have JLCPCB print a new motherboard.
My Github
Circuit Board Repair Manuals
Reply 35205 of 53282, by bjwil1991
If it's the PSU, you're in luck. And if the battery was removed long ago, double luck.
Reply 35206 of 53282, by CrFr
waterbeesje wrote on 2020-07-20, 16:59:
Nice catch! I don't think you overpaid... It's not a bargain either. Just anok price. These machines are generally quite popular […]
CrFr wrote on 2020-07-20, 14:40:
Bought this Compaq Prolinea 4/50S for 66€ including shipping. I don't know if I overpaid, but I have wanted a 486 or 386 desktop system with ISA slots for some time. It has integrated Tseng ET4000/W32i graphics, which I suppose is decent for DOS games. Hard drive is missing, hard drive mounting plate is missing, floppy drive doesn't work, but otherwise it seems to be ok. It is dirty, but after good cleaning, I'm sure it will look very nice 😀
Nice catch! I don't think you overpaid... It's not a bargain either. Just anok price. These machines are generally quite popular.
Floppy drive may just be dirt as well I guess. Clean it and you're probably all set.
For a hard drive a CF card would do perfectly, cost close to nothing and is reliable.
And do yourself a favour: see if you can set the base clock from 25 to 33MHz... The CPU will most probably just be a dx2-66 which is purposely clocked down by intel to fill a market gap 😀
Thanks for the tips!
I tried cleaning and lubricating the floppy drive with no results. When I grew a bit annoyed with this drive, I noticed that it reads floppies just fine if you slam them in angrily 😁 This needs more investigating.
Indeed the CPU overclocked nicely to 66MHz. The case had even nice diagram of jumper locations to make it easy. Runs at higher speed without problems. It is 486SX2-50 processor.
Hard drive on the other hand wasn't as smooth sailing. This machine seems to be very picky on what it accepts. First I tried 8GB CF card, but it didn't work. Always gave hard drive error on boot. Same result with several "modern" 60-120GB drives. Also 128GB SATA SSD with SATA-PATA adapter didn't work. Only drives that work were 1.6GB and 2.6GB ones I had. Both of them sound awful, so it won't be permanent solution. I ordered couple of different 1GB CF cards hoping I might have better luck with those.
Reply 35207 of 53282, by Cyrix200+
I spotted this ELV PCT-7000 PC-card-tester on my local auction site. Not sure how useful it is for me, and I need to find the documentation (still seems to be available from ELV)... Still a cool thing to have and I did not pay too much.
https://at.elv.com/pc-karten-tester-pct-7000-teil-12-203295
Self-developed, newly built or defective PC plug-in cards should be subjected to an independent test in order not to endanger the computer. The PC card tester developed by ELV is used for this purpose. It works without an external computer and can be used to carry out essential functional tests on PC plug-in cards.
1982 to 2001
Reply 35208 of 53282, by chrismeyer6
That tester is a very cool find. Please let us know how it works when you get it.
Reply 35209 of 53282, by BloodyCactus
I'm 100% guaranteeing you its battery corrosion has eaten the board away in a large swathe. those old PSU are fairly rock solid.
Reply 35210 of 53282, by wiretap
BloodyCactus wrote on 2020-07-22, 15:49:
Thank you for your opinion. We'll see when it arrives.
My Github
Reply 35211 of 53282, by Miphee
I can't have a decent retro computer without a bunch of colored 5.25 disks next to it!
Reply 35212 of 53282, by creepingnet
Because I'm a masochist, and I wanted a 486DX4 laptop with a sound card, and like challenges like building up hinge mounts out of thick gumps of SteelStik and J.B. Weld original, and taking my chances on 1990's era touch screens......I bought this NEC Versa M75.....and I have no idea what the heck that "Commpac Words+" System 2000 thing is, but it looks like a piece of medical equipment involving sound.....hey, maybe I'll find a musical purpose for it...who knows. Quite excited to see what I can do with this one after all the greatness my Versa 40EC has risen to. Heck, maybe I can LAN Game with the wife over wifi with this. I've got a WaveLan Silver that's sitting around doing nothing right now.
~The Creeping Network~
Reply 35213 of 53282, by yawetaG
creepingnet wrote on 2020-07-23, 03:06:
Apparently a system for augmentative communication (read: extra-loud voice-over). Later version PDF:
http://www.aactechconnect.com/products/pdf/106.pdf
Great for use at protests/people who won't keep their distances/parties* 😉
* circle your current fancy.
Reply 35215 of 53282, by LewisRaz
Turbo -> wrote on 2020-07-23, 08:02:
LewisRaz wrote on 2020-07-19, 11:29:
Won this motherboard on ebay the other day although I am having trouble finding its ID.
Your board looks similar to mine. Check Jumper settings for 486 motherbaord thread.
Thanks for that 😀
My retro pc youtube channel
Twitter
Reply 35216 of 53282, by appleg33k85
Picked up these two beauties at a flea market. The Zenith is a ZDH-1217-DE that is really clean, looks like its hardly been used but can't really test much since I don't have a monitor compatible with it 🙁 Also can't find much information on it, see others that are -A0 but not really anything on what the -DE is.
Other one is an IBM clone that came with a 386 board, most everything inside is in really good shape except for the battery leaking and making general chaos.
Got everything including 2 keyboards for $140 so felt pretty good about that.
Reply 35217 of 53282, by Carlos S. M.
bjwil1991 wrote on 2020-07-21, 22:40:
Pentium overdrive were based in a later Pentium core (P54C iirc)
Reply 35218 of 53282, by imi
well I couldn't resist on this one...
got a scrap lot of a whole lot of mobile CPUs, mostly PII/PIII? some random boards... they were mostly broken...
but then there was a whole bunch of suspect PCBs mixed in there...
a bunch of mobile 486s one of which is definitely broken unfortunately ^^
two QFP 386DX40, one HIIT 3C87-40
MS6905 MASTER slot1/370 adapter, backplate ripped off, PCB looks fine
then for the more interesting ones 2nd row left to right:
Socket 5 to socket 7 adapter? components ripped off/snipped but PCB looks fine, should be fixable, need to find more info about this one ^^
two 486 VRM adapters, one of which had the VRM snipped off, should also be fixable
one 486 socket adapter with a Cyrix CX487S
and in the 3rd row a Powerleap PL-Pro/II socket 8 to socket 370 celeron adapter that looks to be in good shape :3
and the one big adapter on the top that I can't quite figure out yet... fits a 386DX CPU on... what exactly? 486 boards? x3
the part number yields no results unfortunately.
all of them have some bent pins, one of the 386s has two broken pins... but all in all a good bunch
Reply 35219 of 53282, by mkarcher
imi wrote on 2020-07-24, 16:06:
It's not as absurd as it might sound. There actually are some chipsets that can work with either a 386DX or a 486 CPU, and there even are 386/486 combo boards like this one: http://www.uncreativelabs.de/th99/m/E-H/31611.htm.
It's possible that this adapter is meant for a 386/486 combo board that has a 486 socket only, but is able to redefine a couple of pins to use the 386DX front-side bus protocol instead.
