First post, by OSkar000
A while ago I got an old 386 just because I wanted some parts of the case for another build. Since it would be a shame to waste a perfectly good (ehum) 386 I thought I should give it a chance to live again.
What we have is a Facit S333T, orignally a 386 DX 33 but upgraded with a Cyrix cpu, probably running at 66mhz.
Looking at the date-codes on the components it probably from 1990. Can't really get any more clues about model/manufacturer from looking at it an trying to google any of the info i have from the card doesn't give any hits. Other Facit-computers I have had thru the years has been produced by Mitac but I don't see their name anywhere on this model.
Onboard IDE, floppy, serial and parallell port
8 SIMM sockets
8 ISA slots
non standard AT-connector, not ground in the middle
external battery (not leaking!)
128k L1 cache (is that even possible on a 386?)
unknown memory size. Speedsys reports 22mb, bios says 8mb.
Case on top in the middle.
Motherboard
