Reply 35241 of 58438, by Cyrix200+
OMORES wrote on 2020-07-28, 15:17:
This Soyo Super Socket 7 board which looks like new:
<snip>
Should be a nice board! What CPU did you get with it?
1982 to 2001
Reply 35242 of 58438, by chrismeyer6
Wow that board looks like it's never been out of it's box and it also has the ps/2 and serial port bracket. That's a excellent find my friend
Reply 35243 of 58438, by OMORES
Cyrix200+ wrote on 2020-07-28, 15:33:
<snip>
Well, the CPU is from another movie... a Pentium-S 100 Mhz. (And I had a K6-2+ 550Mhz (with 128K on chip cache) I gave it for free....)
Meanwhile I tested the board - everything works fine... I plugged a PCI-SATA and booted from SSD with no fiddling around...
What If a Modern GPU Had 1990s Bandwidth?
Reply 35244 of 58438, by waterbeesje
OMORES wrote on 2020-07-28, 16:24:
<snip>
Imagine: a Pentium 100 with SDRAM and AGP. Clock for clock faster than you'll expect 😀
Stuck at 10MHz...
Reply 35245 of 58438, by mkarcher
alienmannequin wrote on 2020-07-28, 11:28:
So, it's Compaq-specific. I have the square-shaped piggyback module - there are quite a few numbers on it that are mostly hidden. Have taken more photos of the layout of the board, as well as the oxidation of sorts - haven't done cleaning yet. Wasn't keen to remove the upgrade module yet - looks as if there might be some brittle plastic flathead bolts holding it on, however managed to wedge the camera for a partial shot of the underside.
That partial shot clearly captured the text "4MB - 32 B - M MODULE" which quite surely mean "4 Megabyte 32-Bit Memory Module". That's interesting, as the base card is a 16-bit memory card (unsurprising for a 386SX machine). So it seems the square-shaped piggyback modules might be the same for both the 32-bit base card and the 16-bit base card. And indeed, the 32-bit Compaq Deskpro 386/20 configuration guide at http://ps-2.kev009.com/ohlandl/PS2_MOST/ACROR … PAQ/2005010.PDF actually lists the part number as well. It seems not all modules are interchangable, though.
Reply 35246 of 58438, by CrFr
Bought another one of these Pioneer slot drives. This is the third one I've bought. Two others died quite soon after purchase. Maybe this will last 😁
I just like how they look. Bit different than typical PC drives, somewhat eyecatching when someone has one of these in their machine.
The attachment 20200728_184049890_iOS_.jpg is no longer available
Reply 35247 of 58438, by pete8475
CrFr wrote on 2020-07-28, 22:08:
Hopefully it lasts but it seems like the main thing those drives do is die.
Reply 35248 of 58438, by chrismeyer6
I've had luck with opening the slot load drives and giving everything a good cleaning and relube and they've came back to life. Since there not really sealed like a standard tray alot of dust a debris gets in and gums up the works.
Reply 35249 of 58438, by pentiumspeed
I fell over when I opened up Deskpro 4/33i that arrived today to find out this is one of convertible 486 processor or 386DX 33 with 395DX 33 16K cache controller motherboard installed. I have another motherboard with 386DX pre-installed as backup. This computer contains 486DX 33 processor currently installed. No 64K cache card installed which still are very rare item than anything else.
Came with Conner 100MB hard drive. .. blech, will swap this turd out later with more reliable and faster hard drive later. I had bad experience with Conner back in the day. Slow and unreliable. I had three hard drives back in the day: Had repaired Conner by replacing the blown Cirrus Logic ATA interface, also very easy to fail and incompatible with master/slave if you wonder where my strong dislike comes from: Conner 200MB and IBM 270MB and Quantum 210MB, both IBM and Quantum is much faster.
This replaces the other Deskpro 4/33i with non convertible motherboard but unfortunately in poor condition (rust) and smashed front bezel.
Cheers,
Great Northern aka Canada.
Reply 35250 of 58438, by CrFr
Picked up some more junk 😀
According to seller it is:
IBM Aptiva Model 2170-26G
AMD K6-2 450Mhz / 128MB / 4GB HDD / CDRW / NIC / MODEM
Seller says it doesn't start, nothing happens when power button is pressed. I'm hoping it is just a matter of replacing the PSU. Even if it is totally trash inside, I'm happy to have this cool looking good condition case. It seems to accept normal mATX motherboards and ATX power supply, so it would be fun case to build some sleeper system in it.
The attachment 20200729_095130476_iOS_.jpg is no longer available
Reply 35251 of 58438, by Emu10k1
I have two of those, but in CD-rom version.
One of them is in an optiplex Gx1 and has been working for years without issues, while the other one has been opened and cleaned more times than i care to count just to end up giving problems some weeks later again.
May your drive be blessed with everlasting durability.
Reply 35252 of 58438, by Bancho
Picked up this curious Parallel Backpack Bantam CD-ROM/16-Bit Sound Drive. Its came with the floppy disks but these would not read, but managed to find the drivers online. At first the drive was struggling to read disks, so i cleaned the eye with some alcohol and a cotton bud and it reads them fine now. I've not yet got the sound capabilities working yet. This will be use on my Armada laptop.
Reply 35253 of 58438, by NyLan
Looks like my first DVD Drive ! I remember I had loading issues after few years 😀
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 35254 of 58438, by Dimitris1980
Roland CM64 sound module new and sealed came today to my office 😀
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower, Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
Reply 35255 of 58438, by imi
very nice :3
I'm jelly x3
Reply 35257 of 58438, by PC Hoarder Patrol
Picked up a NOS case locally for €12, a Lian Li PC-A55
The attachment LianLi PC-A55.jpg is no longer available
First thoughts are to mod a basic window in the side panel and use it for a dual build, possibly skt370 coppermine. With its front-mounted psu I may also rethink its position (top or bottom).
Reply 35258 of 58438, by Warlord
the air flow design on that case tho makes little since.
Reply 35259 of 58438, by yawetaG
Warlord wrote on 2020-07-30, 04:18:
Why not? The bottom is likely perforated, and as you can see on the pictures there's room below most of the bottom plate. Hot air naturally rises, and gets expelled from the top.
Of course the design is also a great vacuum cleaner (unless it has good filtering in place).
