Reply 35840 of 58861, by pentiumspeed
Amiga 2000 motherboard?
Cheers,
Great Northern aka Canada.
Cheers,
there's so much in there to spot, it's hard to define the most "valuable" item, but it's sure got some rare ones ^^
also glad it worked out in the end 😀
I think Pentium speed deserves the board 😁
Talking of more hot running, recalled Pentium iiis..
Apparently Xeon PIII heatsinks were still not big enough 🤣
SL4HE 1000Mhz 133Mhz FSB 256KB Cache Slot 2 Xeons
For scale..
Happy to find these too
SL5QW 1100Mhz 100Mhz FSB 256KB Cache Slot 1 Coppermines
Ye already be disturbed; now leave me be. Yer company be toil enough as is.
Amiga 2000 Rev 4.x motherboard is my guess as well. Should be a pretty easy repair -- even with mine having terrible battery damage, I was able to revive it without issue. I only needed to fix 2 traces, and the traces on that board are pretty big.
Edit, and is that a 68030 accelerator below it? That would be the most value..
wiretap wrote on 2020-09-08, 19:44:Amiga 2000 Rev 4.x motherboard is my guess as well. Should be a pretty easy repair -- even with mine having terrible battery damage, I was able to revive it without issue. I only needed to fix 2 traces, and the traces on that board are pretty big.
Indeed, this is one of the most interesting parts. Its a 68040:
http://amiga.resource.cx/exp/overthetop
Very nice. That should be very speedy with a 68040. 😁
Amazing find Predator, IMI
Picasso IV board there too? Might actually be the most valuable
and that's not the end of it ^^ ...tfw nobody appreciates the whole A1200 Tower system 😁 ...well minus the tower unfortunately 😒
Of course, i do spot several MCA cards, but one of them is not famillar for me. But I finally spotted pieces that upgrades the amiga plus few cards, hard drive card for amiga, one of them looks like 486 or 68040 even 68060 accelerator card.
And there's 030 accelerator board for the amiga A600 or A1200.
I'm sending you a PM.
Cheers,
NICE! Supermicro S2DG2! the 900/2m/100 chips are the BEST things you can use in that board. The 1000/133/256's are totally worthless. They are no different than using slot 1's.
@predator99
I wish the electronics scrap here in the US was HALF as good as the stuff you get.
Dang, I didn't even notice the 1200 boards and mediator 🤣. That is indeed a nice haul.
@luckybob
Absolutely, I was stoked to finally find the 900/2/100 one on home soil (I read you have 2 of the beasts). I just got the others for benchmark comparison fun.
I'll create a build thread eventually.
luckybob wrote on 2020-09-08, 20:10:@predator99
That lot is getting better and better. Imi identified this one:
http://amiga.resource.cx/exp/blizzardppc
A1200 Blizzard PPC / 603e & 603e Plus
processor
PowerPC 603e @ 160 / 200 / 240 MHz
68LC040 or 68040 @ 25 MHz or 68060 @ 50 MHz
can be ordered without a 680x0 companion CPU to fit an existing one into the socket
Montaron wrote on 2020-09-08, 19:18:Been hiding these for a while, especially the board :D […]
Been hiding these for a while, especially the board 😁
Supermicro S2DG2
_20200908_200406.JPGXeon 900Mhz 2MB Cache Boxed, Sealed and now well... ;p
(This CPU should of been recalled I think)
Real3D Starfighter PCI 16MB
_20200908_200807.JPGNot seen a Supermicro S2D** board since i got it moons ago. It takes the 700mhz, 900 mhz CPUs fine.
Overclockable to 112mhz FSB in the bios. 133MHz FSB by software.
900 Mhz Xeon is multiplier locked and can do 1008Mhz (112MHz x9), needs a vmod for higher! I call it the Tualatin killer.
700Mhz Xeons and below are unlocked, need to check if setmul can work with them. Fastest at 864Mhz (133MHz x 6.5)
Wow, like that!
I guess it is some form of server or workstation board. Which chipset is it on the board?
Thanks!
Based on the 440GX Chipset. SMP version of the 440BX that supports up 2GB of ram.
https://www.anandtech.com/show/72/11
Hard to tell if this one is intended as a server or a workstation or just trying to cover both but very handy to have a AGP slot 😀
Cool things about it is multiplier control (3-7x), a small overclock option, no terminator need for 1 CPU operation and mismatched CPUs are okay for slot2 in general .
Not a lot of time for this hobby lately, but I did get this Abit KA7-100. with Athlon 750MHz.
Caps look ok, no? /s
1982 to 2001
wow that's crusty x3
Some of them look bulged at the top? I would be very surprised to find any Slot-A/Socket-A boards with healthy caps to be honest..
I have a K7M with good caps ^^
But yeah this one looks really bad
appiah4 wrote on 2020-09-09, 12:15:Some of them look bulged at the top? I would be very surprised to find any Slot-A/Socket-A boards with healthy caps to be honest..
Recently during summer bought an Asus K7M and an Abit KT7 (socket A) which their capacitors on healthy condition. The K7M came boxed with it's manual.
DOS IS THE POWER OF OUR CHILDHOOD MEMORIES!
