Reply 620 of 1171, by red-ray
- Oldbie
mastergamma12 wrote on 2020-08-30, 18:14:Everything looks good apart from fan names, fan names should be CPUFan1,SYSFan1 and AUXFan1.
Thank you for the report, but what about the DRAM timing information?
Please try the attached SIV32X 5.52 DRAM-05 test SIV and check the DRAM timings are the same as other utilities report.
The W83627HF reports several other SIO voltages which SIV may need to report and I wonder, what does the BIOS report?
