First post, by AeonG
- Newbie
Good lord has my journey to build a Windows 98 PC been wrought with frustration. I finally got the power supply this PC has been needing for a while, and now when I boot it up, it wont recognize my "hard drive" (CF card reader) or my DVD drive. Heres the thing though: It worked just fine last time I had the exact same power supply in a month ago. I'm knowledgeable about computers, but probably not as much as you guys, so i'll try to tell you all every thing I know about my situation, first the image:
My specs:
Power Supply: EVGA Supernova G2 550w taken from my main rig after I upgraded. I have a molex cable plugged into one of the SATA slots on the PSU, Having it plugged into "Peripheral" did the exact same thing, and I also tried the molex cable that came with the Corsair RMX power supply I upgraded my main PC with...it didn't even work for some reason.
Motherboard: Tyan Trinity 400 (the version with onboard sound and no ISA). I got it off ebay with the Pentium III processor and memory already installed, and the jumpers obviously already configured, though I doubt they would be causing this. The seller said the board was "refurbished" maybe I made the mistake of thinking they recapped it.
"Hard Drive": Startek CF to IDE card reader
I'm going to order new IDE cables,if it may fix the problem. If possible, would getting an IDE controller possibly fix this problem, and would it be hard to set up? If I have to replace the motherboard, what are some Pentium II/III motherboards that are known to be reliable?
