First post, by lafoxxx
I was stupid enough to install latest Beta BIOS from ASUS website, and now cannot flash Custom version (with fixes I need) from x86-secret because it's based on Release version (with lower build and older date) and EZ Flash Utility tells me I need to boot from floppy if I want to flash older BIOS (not an option because my only FDD unit doesn't seem to work).
Tried renaming the ROM file after the program checked it -- but it seems that the file is loaded into RAM before you can flash it.
Are there any other options?
