Reply 36680 of 53134, by Aublak
- Member
Robin4 wrote on 2020-10-29, 23:24:https://stason.org/TULARC/pc/motherboards/E/E … 486-4MHL3S.html
Isnt that pentium overdrive for a socket 5 or 7 motherboard? Because i think you bought not the right one.. But these socket 5/7 are kinda rare and worth a lot of money.. Shouldnt share that one with an recycler. Should keep or sell if its the wrong one.
What your are looking for is a Pentium overdrive in white / blue silkscreen on the ventilator.
I'm pretty sure its the right one. It fits in the 486 socket. https://cpumuseum.jimdofree.com/museum/intel/ … overdrive/#swap
Also I figured out how to open the fan. You just have to pinch the two tabs together in the upper/left corner.
