First post, by iVirtualZero
Update: Ouch i screwed up both CPU’s but fixed my motherboard and ended up replacing the cpu’s. Will never do this again, blades just don’t work in this situation. Original post: I decided to Delid my Retro PC build as i have successfully Delidded many PS3 consoles. But the same method didn’t work on one of my CPU’s. As i ended up scratching multiple traces and slightly damaging the dye. I scraped some of the paint off with a fiber glass pen to double check, and yes the traces were damaged . But the second one seems like it was a success as i used a different method using my thinner 32 gauge knife and could not find a scratch. I ran the PC with two of my CPU’s before checking for damaged traces. But one of the semiconductors next to the damaged CPU on the motherboard got fried. I removed the damaged cpu and the pc seems to be running fine. With the other CPU, nothing else is getting fried. But i get no video signal. I will be replacing the semiconductor. And as these CPU’s have adaptor sockets installed. Is there a way to desolder the adaptor? Update: I’ve successfully desoldered the adaptor using a rework station.
