Reply 681 of 693, by red-ray
I noticed SIV did not have support for S3 Savage3D (86C390+86C391) GPUs so I added it for SIV 5.53 Beta-02.
If you have an S3 Savage3D please post Menu->Machine->GPU Info so I can check the correct clock speeds are reported.
Reply 682 of 693, by grey_beard
Just a quick question from my side:
Is there a section for IrDA somewhere in SIV as it's quite common on old machines?
I would have expected to find it somewhere in the Network section but couldn't find anything. Would be interested in what speeds etc. are supported on my hardware.
Reply 683 of 693, by red-ray
grey_beard wrote on 2020-11-20, 20:58:
Thank you for your post. SIV checks for GUID_DEVINTERFACE_IRPORT devices and it it finds any then there should be Menu->System->ACPI + PnP->IR Ports, is it there please?
For 5.54 Beta-02 I will change the name to ->IRDA Ports and will add Menu->Network->IRDA Ports.
Have you found Menu->Help->View Menus?
Reply 684 of 693, by grey_beard
red-ray wrote on 2020-11-20, 21:33:
Unfortunately "IR Ports" doesn't show up in that menu, although the port itself is working fine and shows up in the windows device manager. Just used it a few weeks ago to sync an old Palm device.
I'm running SIV on Windows 10 N (32-Bits) on an old Thinkpad X60s.
Reply 685 of 693, by red-ray
grey_beard wrote on 2020-11-21, 12:57:
I would expect it to show up on W10 and should be on Menu->System->Interfaces as below.
To really know why it's not I would need you to do Menu->File->Save Local and post the two files that are generated.
    93.73 KiB
    Winbond CIR Transceiver
Reply 686 of 693, by grey_beard
Nope, the port doesn't show up in the interfaces menu, instead it shows up in the list of "ACPI Devices" as to be seen in the screenshot attached. It's the "IBM ThinkPad Fast Infrared Port" right at the bottom.
The report you were asking for is also attached.
    SIVReports.zip
    317.37 KiB
    2 downloads
    19.67 KiB
Reply 687 of 693, by red-ray
grey_beard wrote on 2020-11-21, 14:00:
I know why and don't think there is much I can do about this. It's using the National 6.0.6001.18000 driver which looks like it fails to expose the GUID_DEVINTERFACE_IRPORT interface. Looking at Menu->System->DOS Devices I found:
ACPI#IBM0071#4&224b442a&0#{ad498944-762f-11d0-8dcb-00c04fc3358c} \Device\00000028
ACPI#IBM0071#4&224b442a&0#{cac88484-7515-4c03-82e6-71a87abac361} \Device\00000028
{cac88484-7515-4c03-82e6-71a87abac361} is GUID_DEVINTERFACE_NET and {ad498944-762f-11d0-8dcb-00c04fc3358c} is GUID_NDIS_LAN_CLASS neither of which identify the device as IRDA 🙁 On systems where SIV finds IRDA devices there is such as:
ACPI#WEC1022#1#{064f8c82-77b2-445e-b85d-c4e20f942fe1} \Device\00000022
{064f8c82-77b2-445e-b85d-c4e20f942fe1} is GUID_DEVINTERFACE_IRPORT .
On the plus side I was pleased to see SIV automatically detected five ACPI motherboard temperature sensors 😀
I have now released SIV 5.54 Beta-02 which should list your IRDA device as a Net device on Menu->System->Interfaces, does it please?
Reply 688 of 693, by red-ray
From SIV 5.54 Beta-02 SIV should report all three fans on EVGA RTX 3080 + 3090 + all FTW3 GPUs, but I have only tested this on my EVGA RTX 3080 XC3 Ultra. If you have an EVGA RTX 3080, 3090 or FTW3 GPU please will you check if SIV reports all three fans and post the Menu->Machine->GPU Info panel. If only two fans are reported also post Menu->Machine->GPU I2C which should enable to to add the third fan.
file.php?id=96777
Note that currently SIV is only able to report all three fans for EVGA GPUs.
    43.34 KiB
    EVGA [GPU I2C] panel
    95 KiB
    SIV reporting 3 fans on an EVGA RTX 3080 XC3 Ultra
Reply 689 of 693, by grey_beard
red-ray wrote on 2020-11-21, 14:53:
Yes it shows up between the "Net" devices as "Infrared-5".
    58 KiB
Reply 690 of 693, by red-ray
grey_beard wrote on 2020-11-22, 20:34:
Ah, I had not spotted the class was Infrared. I could use that to detect it, but given it's not GUID_DEVINTERFACE_IRPORT I expect it won't support IOCTL_IR_GET_DEV_CAPS so even if I used the class being Infrared then the IOCTL_IR_GET_DEV_CAPS would probably fail anyway.
I have built the attached SIV322X 5.54 IRDA-03 test SIV, would you like to try it and report what gets reported?
IOCTL_IR_GET_DEV_CAPS definition
// Module Name:
// irclass_ioctl.h
// Abstract:
// This module contains the IOCTL definitions for the WDF IRCLASS class driver
#define FILE_DEVICE_IRCLASS 0x0F60
#define IOCTL_IR_GET_DEV_CAPS CTL_CODE(FILE_DEVICE_IRCLASS, \
1, \
METHOD_BUFFERED, \
FILE_READ_ACCESS)
Reply 691 of 693, by grey_beard
red-ray wrote on 2020-11-22, 20:56:
It reports "Unzulässige Funktion" which I would translate into "illegal operation".
    8.82 KiB
    No downloads
Reply 692 of 693, by red-ray
grey_beard wrote on Yesterday, 15:47:
file.php?id=96867
Thank you for checking it out, this is what I was expecting and in the header file Status 1 is as below.
I feel I should leave the code there so the IRDA port is at least listed on Menu->Network->IRDA Ports, what do you think please?
// MessageId: ERROR_INVALID_FUNCTION
// MessageText:
// Incorrect function.
#define ERROR_INVALID_FUNCTION 1L // dderror
