Reply 17300 of 27641, by wiretap
the_ultra_code wrote on 2020-11-26, 18:38:
Finished cleaning and updating the BIOS on my Asus A7V880 Socket A motherboard, and I've run into a weird issue. https://i.imgur […]
I get this error from a "slow boot" (i.e. not a Quick Boot) when I populate all 4 DIMM slots on the motherboard with 1GB sticks of DDR-400 (I've tried both G.skill and Corsair kits). According to the manual, the board supports 4GB of RAM, and the chipset technically supports 8GB, so I don't think I'm using too much. Each pair of DIMM slots works normally individually, but when all 4 are used I run into this error, with detected RAM maxing out at 2.5GB. I'm testing with a Sempron 2000+ that came with the board.
Any ideas?
The user manual says to use only 2 DIMMs when using DDR400, or else you can get unstable performance. Try 4 DIMMs of slower RAM and see if it works.
My Github
Circuit Board Repair Manuals
Reply 17301 of 27641, by Bruninho
Fancy doing this for holiday season? https://www.youtube.com/watch?v=UpAnV8SLzh4
Download: https://www.majorgeeks.com/files/details/holiday_lights.html
Runs on: XP and later
I remember I used to do that on Windows 98, but I couldn't find a version for that one.
JOBS, Steve.
Reply 17302 of 27641, by schmatzler
ragefury32 wrote on 2020-11-26, 23:30:
Hmmm...that’s an RU28 TSSOP with 0.65mm pitch - did you use solder paste, and if so, which brand did you use? Did you follow any Pre-heating procedures? I was aiming for 5 ADP3421s off a reel from a reputable dealer instead of junk pulls...
I just use regular flux, because I bought a big bottle of that many years ago (noname from eBay) and flux paste is pretty expensive.
Every time I remove a chip like that it pretty much goes like this:
- Putting Capton tape around the chip if there are very small resistors so I don't blow them off the board
- Filling up a small syringe with a bit of flux and gently applying it under the chip
- Setting my hotair station to around 280°C - 320°C with a small nozzle and moderate airflow. It only has one knob to control it and 50% of power seems to be enough. Setting it higher makes components fly off, setting it lower and the chips don't want to move.
- Directing the heat only onto the chips surface/legs and tapping it with tweezers until it moves
For soldering in the new one I don't use hotair afterwards. I clean up the board with solder wick and use the iron to solder in the new one.
Sometimes when a chip is struggling I adjust the heat a little higher and/or put more flux on the chip again and that pretty much makes it work then.
One day I will try BGA reballing, a big package of various stencils is already on its way here. Now I just need a machine with a broken BGA chip... 😀
Reply 17303 of 27641, by Dmetsys
debs3759 wrote on 2020-11-27, 17:03:
RetroLizard wrote on 2020-11-27, 16:41:
Does anybody know if this is a good 486 board? https://i.ebayimg.com/images/g/G5QAAOSwRBpehgo4/s-l1600.jpg […]
It looks like an early board with a Weitek socket. Not sure whether the jumpers near the CPU are for different CPUs, but with only 30-pin SIMMs and ISA slots it certainly isn't high end. If you are looking for Weitek support, it may be OK, but if you want to run a range of 486 CPUs it probably won't be so good.
I concur. The 82C493 is limited to 33 MHz, supporting Writeback cache. It'd be better to start looking for SiS 471 or newer based motherboards if you want a good 486 experience.
A7N8X-LA | 2800+ | GeForce2 MX400 | Audigy 2 ZS
BE6-II 1.0 | PIII-933 | Viper 770 TNT2 | Live 5.1 Value
MS-5169 | K6-2 450 | Voodoo3 3000 AGP | AWE64 Value
P5A-B | P200-S | 64MB | MGA Millennium | Yamaha 719
LS-486E | Am5x86-P75
Reply 17304 of 27641, by Caluser2000
Fired up the SHARP PC-1500 from 1983. Haven't fired it up in six or so years. Absolutely no problems at all. Has nice ali front too.
Even back then portable computers had battery power saving features. Believe it or not....
    206.14 KiB
Reply 17305 of 27641, by ultra_code
wiretap wrote on 2020-11-27, 17:26:
I tried running the RAM at 333Mhz, no die.
Builds
Reply 17306 of 27641, by Jed118
Got a rando PII board out of an auction a couple weeks ago, and I finally had a time to look at it.
Bulging caps. POST and even boot no problem, but since this is a category 2 machine for me, I invested the $9CAD and ordered the right caps for it.
Here are the old ones, popping the tops and nothing I am unfamiliar with. Actually, this exercise ameliorated my soldering techniques - it was basically a swap of soldering tips, one that could go through the hole in the motherboard directly to the other side where my solder sucker waited - 9/10, it was met with success, 9 capacitors were replaced with ease.
One beer was consumed.
Success!! (for now)
So I screwed the motherboard in. I had to use the pliers to make adjustments to the case, as the standoff seemed like it would interfere with the board. Got the I/O shield in , mounted the board, and then I realized that the harness would have to be taken apart.
Another beer was consumed.
I returned and realized that I have to do something with this harness, at least slip the power button leads out of it and connect them to the motherboard so as to not act the savage and randomly touch jumper headers together with a screwdriver in order to power on (which is clearly what I was doing when I snapped the POST picture 😁 ) and in my screwdriver manipulations, NAILED the motherboard with it.
Shit.
Turns on, no sounds, no video.
Put in analyzer on ISA - getting -- --
OK. Isolate - take out the video card (PCI), turn on. 8 beeps.
Sweet.
Put PCI video board into another slot.
Nothing.
Slightly panic - look over at 486 SCSI project. Has 8 bit ATI VGA tester card. ISA. This PII board has ISA.
POSTS. Nice!
Next step, try a different bus:
POSTS. Wicked.
It was my intention to use AGP anyhow. To test the PCI bus, I will put a known good PCI video card in it. Then, rebuild an NEC system 😁
Bonus picture of an 8 bit 1988 ATI Wonder POSTing a Celeron 533
A third beer was consumed.
What's for sale? my eBay!
Reply 17307 of 27641, by Dmetsys
That board is an MSI MS-6309 v2.0. Good little Coppermine/Tualatin motherboard.
Reply 17308 of 27641, by Jed118
Dmetsys wrote on 2020-11-28, 07:10:
Great news! I don't have a Tualatin, but I do have a 1GHz CPU kicking around here somewhere. And a nice CPU cooler for it. Thanks for the info 😁
Reply 17309 of 27641, by drosse1meyer
Trying to fix a retrobright that ran wild...
Reply 17310 of 27641, by SVD
Sooo... I managed to rip off the biggest capacitor on my Voodoo 5 AGP when i was inserting the Molex. Its the 470uf one. Of course the pads went also 🙁
The positive side is connected straight to the +5V of the Molex. Is this just a filter cap, and the negative is connected to ground? I cant see where i should connect the negative otherwise.
Reply 17311 of 27641, by amadeus777999
"Revived" old ASUS P5A with a new BIOS (1007.bin) - diagnose card was showing 0xffff but no picture so I assumed it must be the BIOS since it was the last step in the procedure.
Happy news aside the board's cache is nonetheless smoked but I'll use it without and instead up the fsb. Good enough for a 586 era test board.
    561.75 KiB
    1.57 MiB
Reply 17312 of 27641, by PTherapist
Finally got myself a working Commodore Plus/4 yesterday. The keyboard wasn't working correctly, several keys not working and other keys doing things they shouldn't. So I opened it up and found the culprit - a deteriorating keyboard ribbon cable.
But I did manage to get it working again by reseating the cable, then bending it one way followed by folding it another and then pressing the case back down onto the cable to hold it in place. Did the trick, keyboard is now fully functional. I'll be leaving it like that for now and I'm going to keep on the look out for either a replacement keyboard or a broken spares/repairs Plus 4 on eBay to strip for parts. My soldering skills are nowhere near advanced enough to try replacing the ribbon cable itself, plus the keyboard is missing a key and spare keys for the Plus/4 are pretty hard to come by.
Keyboard issue aside, I cleaned the computer and applied IPA to the expansion ports and I've spent most of today playing games on this Plus/4. Trying out the games that I got with it as well as those on my SD2IEC.
My next maintenance job is to try and restore the 4 joysticks I have for it into some sort of working order, they all have issues with the fire button or certain directions. If I can at least repair 2 of them, that'll be a bonus. But in the meantime I have a DB-9 adapter to use proper microswitched joysticks instead. 🤣
Reply 17314 of 27641, by Robin4
The new table is installed today.. So soon i can relocate my hardware and other stuff to it..
Maybe iam going it to use for some days to build my systems on, and after that using it to store my stuff on in.
Reply 17316 of 27641, by Caluser2000
RetroLizard wrote on 2020-11-28, 23:56:
Obtained a few different retro linux distributions today. Will post images later.
We have a thread for old Unix/Linux Re: *nix software and systems
Reply 17317 of 27641, by Dmetsys
Made some more retro purchases, increasing my debt load even more. 😁
Reply 17318 of 27641, by luckybob
I just finished "upgrading" my NAS storage by about 20%.
On the left are 24 new (ish) 1.2tb, 10000 rip'em SAS hard drives with 128mb cache. On the right are the drives getting replaced. 24x 1tb, 5400 rip'em drives taht have been running 24/7 since 2015. Needless to say, i've put some some serious mileage on drives designed for "light" work only. I dropped $800 on the new drives (new sas controller and cables too). I had 2 of the slow drives fail in 2 months, get replaced and suddenly 2 more go into the yellow. The new disks are re-branded Seagate ST1200MM0129. they might be spinning rust, but they can really haul ass. Even with encryption, data compression, and a very conservative 3x8 zfs3 pool config I can still saturate a 20gb/s ethernet link. maybe I might snag a small used intel optane drive and use that for an L2arc?
In other news, I went totally Office Space on my old Brother Printer. I bought brand new toner for it, only for something in the paper path to screw up. I wasn't having a good day to start with, and truth be told smashing that 100lb monster on my basement floor felt AMAZING.
Side note, I REALLY should have taken the brand new toners out before I smashed it. CMYK toner is expensive.
Reply 17319 of 27641, by Dmetsys
If I could take a baseball bat to every Xerox and Samsung printer I'd have to service over years, I would. I don't miss that industry in the least.
