Reply 17300 of 30906, by wiretap
- Oldbie
the_ultra_code wrote on 2020-11-26, 18:38:Finished cleaning and updating the BIOS on my Asus A7V880 Socket A motherboard, and I've run into a weird issue. https://i.imgur […]
I get this error from a "slow boot" (i.e. not a Quick Boot) when I populate all 4 DIMM slots on the motherboard with 1GB sticks of DDR-400 (I've tried both G.skill and Corsair kits). According to the manual, the board supports 4GB of RAM, and the chipset technically supports 8GB, so I don't think I'm using too much. Each pair of DIMM slots works normally individually, but when all 4 are used I run into this error, with detected RAM maxing out at 2.5GB. I'm testing with a Sempron 2000+ that came with the board.
Any ideas?
The user manual says to use only 2 DIMMs when using DDR400, or else you can get unstable performance. Try 4 DIMMs of slower RAM and see if it works.
