Reply 17540 of 30909, by furan
Shagittarius wrote on 2020-12-15, 04:09:
Caluser2000 wrote on 2020-12-15, 03:05:
Good work Shagittarius .
I was going to run 64MB of FPM and 64MB of EDO together to test but i bent one of the pins in a ram slot, (which I fixed) , but decided it wasn't important enough and just leave it be...The Motherboard says it optimizes both memory types simultaneously, I was curious what that performance would be like.
I imagine that would depend on the address of the read/write.
Reply 17541 of 30909, by Windows9566
I got my ASUS TX97-XV (HP OEM) working with the Award BIOS. I prefer that BIOS over the crippled Phoenix BIOS. I just replaced the 2mbit bios chip with a 1mbit bios chip and hotflashed it with a asus p2b.
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 17542 of 30909, by Caluser2000
Pulled a KTX and Genius parallel port A4 flatbed scanners out of storage. I'm going to tidy the Genius one up as that is my first flatbed scanner. Both glass plates have separated from the body but is an easy fix with double sided tape . As you can see from the photos both have exactly the same internals with minor changes like different lids and stickers. Luckily the KTX scanner had has the driver disk and application CD when I picked it up at a garage sale. My ColourPage-View software CD for the Genius scanner has a huge crack though it but I've got the diver disk somewhere.. KYE, KTX and Genius hardware/products were all basically the same with different detail differences. I've used a lot of their gear over the years (nics, sound cards, hand scanners, mice etc) without any issues at all.
Reply 17543 of 30909, by alvaro84
Since I have a lot of time at home (the spoils of 14 broken ribs, ha-ha) I decided to go through the piled up 20-120GB PATA HDDs. After some trial and error I ended up using an Asus P5A with a patched BIOS. To my surprise, this one can understand the souls of these metal plated Barracudas much better than that FuSi i815 and MSI694T Pro, and much faster at reading/writing them. The k6-3@450 CPU is just the icing on the cake, it doesn't have too much to do while licking through the HDD's surfaces but much more interesting when I actually get up and sit there to watch a few demos or play late DOS games.
And it's not even wasted energy, just some more, rather insufficient, heating for the house.
Ah, and the partitioning is done under pure DOS, with the joint operation of fdisk and pqmagic. Crazy, eh? 😁
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 17544 of 30909, by Shagittarius
alvaro84 wrote on 2020-12-15, 07:52:
Since I have a lot of time at home (the spoils of 14 broken ribs, ha-ha) ...
My god what happened?
Reply 17545 of 30909, by alvaro84
I met a Volkswagen Golf, frontally. All I had was a bicycle.
Reply 17546 of 30909, by Shagittarius
alvaro84 wrote on 2020-12-15, 18:53:
Wow, I'm glad you pulled through, get better ASAP and build some great vintage machines in the meantime!
Reply 17547 of 30909, by appiah4
Get well soon, man!
Reply 17548 of 30909, by RetroLizard
Got a boxed, semi-used copy of an old RPG game from the early 2000's - Dungeon Siege.
Anybody know if it can run on a Voodoo3 3000? If so, how well?
Reply 17549 of 30909, by SVD
I have an option to buy this among a commodore PC 20III
I cant seem to identify it, anyone?:)
Reply 17550 of 30909, by bearking
Didn't know Alcatel made notebooks...
Reply 17551 of 30909, by Bruninho
bearking wrote on 2020-12-15, 22:49:
They did. I think I saw some two decades ago being used by Prost GP in Formula One.
JOBS, Steve.
Reply 17552 of 30909, by Caluser2000
Got the family IBM PC300GL with Celeron 400 back up and running. This was our main computer system between 1999 and the mid 2000s running the original Windows 98 without any major issues at all. Never needed to reload Win98 during that time. Just regular maintenance using CrapCleaner, AVG and had Kario as the software firewall. The Windows install is giving a dll error at present and easy enough to sort out. While I was mucking around with it I tried some Linux, OS2 v3 and OS/2 v4 installations. To my dismay non of them loaded giving kernal panics or OS/2 spitting out trap errors. The culpret was the Legend 128meg PC133 ram stick. Removed than and everything ran nicely from then on with only the 256meg ram stick.
Reply 17553 of 30909, by september0451
Picked up my old family's home computer from my parents basement along with a ton of junk I had been storing in their basement for years. Most of the original bundle of sofware was there in perfect condition from ~ 1995/1996.
So I am now the proud new owner of a near perfect IBM Aptiva 2176-CX3. And I just re-loaded all the factory software from the official IBM product recovery CD. Fresh install of Windows 95 with MS Plus, Going to grab a Win98 SE upgrade ISO from REMOVED....
Even have the original 14" 640x480 CRT.
Reply 17554 of 30909, by appiah4
It was probably made by an OEM for them..
Reply 17555 of 30909, by RetroLizard
RetroLizard wrote on 2020-12-15, 21:19:
The answer is yes, kinda - Main menu runs around 60+ FPS, but in game runs around 15-20 or less.
Reply 17557 of 30909, by ragefury32
I hope you had some choice words with the owner of said Volkswagen Golf.
Speedy recovery and best wishes.
Reply 17558 of 30909, by TechieDude
Holy shit, dude. Get well soon, and I hope your bike didn't get too badly damaged either...
Reply 17559 of 30909, by alvaro84
The bike is completely done for. Unfortunately. But thanks anyway, everyone.
And today I finished with the 20-120GB HDDs so I continued my tests with FDDs and CFs. Storage days, I say.
