Reply 37680 of 53069, by Repo Man11
- Oldbie
PTherapist wrote on 2021-01-16, 11:08:Just to add to the nForce 2 debate, I've recently been putting together old gaming builds and the nForce 2 based build was my mo […]
Ozzuneoj wrote on 2021-01-16, 04:20:In all seriousness, I can't explain why some have had such reliability issues with nforce 2 boards while others have not. Lets all just be glad current PCs aren't like they were back in the early 2000s, at least stability wise.
Just to add to the nForce 2 debate, I've recently been putting together old gaming builds and the nForce 2 based build was my most troublesome.
Using an MSI K7N2 motherboard, it absolutely didn't like an overclocked CPU, with freezes in games. This board also did not like any AGP Radeon graphics cards, with constant crashes and weird behaviour even just trying to run 3DMark. So I had to put in an AGP GeForce FX instead.
The build now at least runs games, but a couple of specific games cause a BSOD in Windows XP after a few minutes of running, for example - Battlefield 1942 is unplayable and Halo at least caused a BSOD once. CPU doesn't seem to be overheating, everything is clean and no visible bad capacitors on the motherboard either.
I really must try running memtest for an extended period as others have been doing, as I am using dual channel. Running memtest for a short while back when I was having problems did not show up any memory errors.
Just in case: if you haven't pulled the northbridge chip cooler off, make sure and do so. If all it has is the original thermal paste, it has become petrified and useless by now.
