First post, by AMDMania
Hi did a search and couldn't find what I'm looking for. I want to remove this 486 chip from the motherboard but I don't know what's holding it in. I'm going to be replacing the board with a 386mobo and processor and co-pro, and I guess I'm wondering when I get to that step, what holds the cpu in the socket?
Thanks
    1.34 MiB
    1.26 MiB
Reply 2 of 11, by waterbeesje
This one is just held by the socket.
It's a lif socket: low insertion force
The socket 3 with the lever is a zif: zero insertion force.
Gently lift it up with a plastic tool, a millimetre a time, every lift a different side.
I don't recommend my usual method: put a screwdriver in between the socket and the CPU and rotate the screwdriver. It may damage the CPU.
Stuck at 10MHz...
Reply 3 of 11, by bofh.fromhell
Something like this:
The CPU is pressed into the holes in the socket.
Think its called LIF, as in Low Insertion Force.
So it shouldnt take much force, tho if its been in there for a long time it might need some persuasion =)
Reply 5 of 11, by Horun
bofh.fromhell wrote on 2021-01-22, 22:14:
Something like this: https://www.vogonswiki.com/images/thumb/1/14/Intel_CPU_removal_tool.jpg/800px-Intel_CPU_removal_tool.jpg […]
Yes !! I have one too. Got it from HP/C in about 1995 or there about.
    509.43 KiB
Reply 6 of 11, by Vynix
AMDMania wrote on 2021-01-22, 23:26:
Ok thanks, I've ordered a plastic screw driver set. Could not find the cpu tool on ebay.
And is Mr. Bios worth keeping? The motherboard has extensive battery corrosion, so I'm tossing it.
Yes. There's a topic in the software section that has a list of all dumped MRBioses. There's a lot of MRBioses that weren't dumped
Reply 10 of 11, by Caluser2000
I just use the short end of a isa slot cover blank. Easy. as...
Reply 11 of 11, by Baoran
I have just used tiny screwdriver and lift each corner of the cpu in turn. I have never felt like there has been danger of damaging the cpu even if I have done it probably couple dozen times.
