Reply 460 of 683, by Mumak
- Oldbie
Nexxen wrote on 2021-01-06, 20:47:Hope it's useful.
Thanks. An interesting system 😀
STB Nitro DVD 4MB AGP (Chromatic Mpact 2).
Takedasun wrote on 2021-01-09, 17:15:STB Nitro DVD 4MB AGP (Chromatic Mpact 2).
Thanks, I'll try to fix the memory size in the next Beta build.
I have a 486 DX4 100 that shows up as 50 MHz in HWINFO 6.12:
During bootup the Bios screen indicates the correct 100 MHz.
mbertheau wrote on 2021-01-10, 00:28:I have a 486 DX4 100 that shows up as 50 MHz in HWINFO 6.12: […]
Can you please attach the HWiNFO Debug File? This can be created by running with the -d argument.
Ok, disregard that. I had the computer out of the case on the table and the turbo was off 😀 It's showing 100 MHz now with the turbo on. And Warcraft 2 runs nicely fast 😀
Mumak wrote on 2021-01-10, 07:53:Can you please attach the HWiNFO Debug File? This can be created by running with the -d argument.
I have a PcChips M326 V5.2 motherboard with an Am386DX-40 soldered in, and I added an IIT 4C87DLC-40 FPU.
The motherboard is detected as M601/602 which is not correct (that one is a 486 board with 3 VLB slots), and the FPU is detected as Intel 80387DX running at 73.6 MHz. Weird. (NSSI detects it correctly)
Here's the debug:
HWiNFO v6.1.2
Flushing disk caches ...
Reading Data ...
DetectCPU - 386
FPUtest=3
Check Cx
Get freq
FreqCPU: 1292-26
Cache 1K: 32.0 -> 32.0
Cache 2K: 62.5 -> 62.5 = 1.95x
Cache 4K: 123.5 -> 123.5 = 1.98x
Cache 8K: 245.5 -> 245.5 = 1.99x
Cache 16K: 489.3 -> 489.3 = 1.99x
Cache 32K: 977.0 -> 977.0 = 2.00x
Cache 64K: 1956.0 -> 1956.0 = 2.00x
Cache 128K: 3908.0 -> 3908.0 = 2.00x
Cache 256K: 20687.0 -> 20687.0 = 5.29x *L2*
Cache 512K: 41366.0 -> 41366.0 = 2.00x
Cache 640K: 51705.0 -> 51705.0 = 1.25x
Check CT
Check FPU: int
FreqFPU: 3632
DetectCPU - 386
FPUtest=3
Resetting CPU [Method 3]
Resetting CPU [Method 1]
CPU ID1=308
Check Cx
Get freq
FreqCPU: 1291-25
Cache 1K: 32.4 -> 32.4
Cache 2K: 62.5 -> 62.5 = 1.93x
Cache 8K: 245.4 -> 245.4 = 1.99x
Cache 16K: 489.1 -> 489.1 = 1.99x
Cache 128K: 3909.0 -> 3909.0 = 2.00x
Cache 256K: 20689.0 -> 20689.0 = 5.29x *L2*
Cache 512K: 41369.0 -> 41369.0 = 2.00x
Cache 640K: 51684.0 -> 51684.0 = 1.25x
Check CT
Check FPU: int
FreqFPU: 3632
AMI ID = 40-0100-001437-00101111-080893-4386
Checking VLSI 330
Checking VLSI 331
AMI STR = AMIBIOS (C)1993 American Megatrends Inc.,
Release 10/01/93.
Searching for BIOS extensions...
Here's another one. In this case, the motherboard is an Octek Jaguar V rev 1.4, also with a DX-40 soldered in. This time the IIT 4C87DLC-40 (which is not the same as the one in the motherboard I posted above) is correctly identified as IIT, but incorrectly as 3C87 (though they might be the same chip).
Debug:
HWiNFO v6.1.2
Reading Data ...
DetectCPU - 386
FPUtest=3
Check Cx
Get freq
FreqCPU: 1295-26
Cache 2K: 63.0 -> 63.0 = 1.95x
Cache 4K: 124.4 -> 124.4 = 1.97x
Cache 8K: 248.0 -> 248.0 = 1.99x
Cache 16K: 1672.9 -> 1672.9 = 6.75x *L1*
Cache 32K: 3350.0 -> 3350.0 = 2.00x
Cache 64K: 6700.0 -> 6700.0 = 2.00x
Cache 128K: 13406.0 -> 13406.0 = 2.00x
Cache 256K: 26808.0 -> 26808.0 = 2.00x
Cache 512K: 53619.0 -> 53619.0 = 2.00x
Cache 640K: 1489.0 -> 67025.0 = 1.25x
Check CT
Check FPU: IIT
FreqFPU: 3640
DetectCPU - 386
FPUtest=3
CPU ID1=308
Check Cx
Get freq
FreqCPU: 1294-26
Cache 8K: 247.8 -> 247.8 = 1.99x
Cache 16K: 1673.9 -> 1673.9 = 6.76x *L1*
Cache 32K: 3349.0 -> 3349.0 = 2.00x
Cache 64K: 6701.0 -> 6701.0 = 2.00x
Cache 128K: 13404.0 -> 13404.0 = 2.00x
Cache 256K: 26809.0 -> 26809.0 = 2.00x
Cache 640K: 1490.0 -> 67026.0 = 1.25x
Check CT
Check FPU: IIT
FreqFPU: 3640
AMI ID = 31-0100-426069-00101111-121291-MXIC
Checking VLSI 330
Checking VLSI 331
AMI STR = AMIBIOS (C)1991 American Megatrends Inc.,
MX_DIR_001
Thanks for the reports, those are interesting systems!
I will adjust the mainboard names so it will be correctly reported.
But the FPU detection is quite strange and I have no clue why the IIT check works on one machine, but doesn't on another one with the same FPU model.
Can you try to open the main screen multiple times to see if the reporting is consistent on each run?
Is there perhaps documentation for that IIT available somewhere?
Mumak wrote on 2021-01-27, 19:40:Thanks for the reports, those are interesting systems! I will adjust the mainboard names so it will be correctly reported. But t […]
If you check THIS POST that I made some minutes ago, you'll see that even if the IIT FPUs are the same externally, internally there are differences. I will swap them around and check how HWInfo behaves in that case. If the "IIT" correct report follows an FPU or remains with the same motherboard regardless of which one is plugged in. I'll let you know later.
Ok, as I had the Jaguar V on the bench I went and removed the fpu and swapped it with the one on the M326, and HWInfo reports it as an Intel 80387DX at 73.6 MHz, just like the M326. So both FPUs are clearly different (even though they look identical) and they might report a different string to software, I don't know.
I tried NSSI and it's also seeing it as and Intel 387 (instead of the IIT), so my quote in the previous posts was wrong, but the frequency differs from HWInfo, it sees it as 53 mhz.
Well, that's interesting. The FPU doesn't report and string, no identification data. It can be only tested using various unique results to detect at least the vendor or type. Various vendors or families have peculiarities that can be tested.
So there's a check method for an IIT FPU (based on denormal result) and the fact that this one reports as 387DX means this check if failing there.
So my conclusion is that it's either some very early IIT FPU or rather a clone attempt of the Intel 387DX or a faked IIT FPU.
Now that I look at more details especially FPU clock detection based on execution time, it's clearly not a 387DX as that one has much longer execution times for certain instructions.
I'd rather say that the brownish one is an early IIT part that didn't yet support all later quirks.
Mumak wrote on 2021-01-27, 20:55:Now that I look at more details especially FPU clock detection based on execution time, it's clearly not a 387DX as that one has much longer execution times for certain instructions.
Yup, the brownish one is ~15 weeks older, which is not that much anywyas. I'm thinking maybe they are different batches of FPUs for different factories (hence the color difference) with different cores. Something interesting I found also, is that there are some IIT 3C87 with the same code as my 4C87DLC, 1002FA2F5HC0C, but they were made on the same date as my brownish one, and are brownish!. If only we could decode that string...
What a mess 😁
PCInfo Version 4.04 detects the black one (newer) as IIT 3C87 / Intel RapidCAD while it detects the brownish one (older) as IIT 3C87 / IIT 3C87sx.
Or maybe the brownish one is somehow defect or unstable and it fails (besides the IEEE test) the generic IIT check. Maybe sometimes, maybe permanently...
Mumak wrote on 2021-01-27, 21:26:Or maybe the brownish one is somehow defect or unstable and it fails (besides the IEEE test) the generic IIT check. Maybe sometimes, maybe permanently...
I don't want to say that's impossible, because obviously it isn't, but pretty improbable. They both work perfectly fine with all software I throw at them, they perform identical even to the decimals in benchmarks that take care of the fpu. They just seem to behave different in some specific area. BTW the one that is detected as "Intel" is the black one. The brown one is detected as IIT.
As I have recently been converting all my daily use machines from Windows to Linux, I was left perplexed by the lack of a "Device Manager", Astra, Everest, or hwinfo type of utility in Ubuntu. While there are a few add-on packages, they are very lacking in detail. I was wondering if there has been any thought in creating a hwinfo version for Linux?
feipoa wrote on 2021-02-16, 00:28:As I have recently been converting all my daily use machines from Windows to Linux, I was left perplexed by the lack of a "Device Manager", Astra, Everest, or hwinfo type of utility in Ubuntu. While there are a few add-on packages, they are very lacking in detail. I was wondering if there has been any thought in creating a hwinfo version for Linux?
A thought there was, yes.. but no time and resources to dedicate to such a huge effort...
HWiNFO for DOS version 6.1.3 has just been released: Re: HWiNFO for DOS resurrected !
I want to submit a bug 😀
Nothing serious really, just that POPAD bug is not always detected on 386DX, and STOS bug is never detected. NSSI doesn't detect STOS bug either but I wrote my own code to test it and I can trigger it.
