First post, by Chaosfuel
Hey guys,
I recently inherited my grandfather's Pentium 75 running Win95. It is in near perfect condition even though it was bought in 1995. The DOS games I installed when I was a teenager were still on the HDD, complete with savegames.
After some advice from a friend I decided to replace the 1GB HDD because it will eventually give out. I decided to go for the Compact Flash route.
I bought a Delock CF to IDE adapter and a CF card I saw on the YouTube LGR channel (Transcend 4GB UDMA 300X).
I desperately want to keep the data that was on the original HDD alive so I made an image of the HDD with Macrium Reflect. I formatted and partitioned the CF card in FAT16 with a 1.9 GB partition. Just because it'll be sure to stay under the 2GB limit.
I expected it to boot, but it's not. The BIOS does recognise the entire card, just not the partition. So I don't know what to. I'd like some advice. Just bear in mind I'm just adequate with computers and probably not as good as you all are.
Thanks in advance.
