Reply 38160 of 59674, by yawetaG
CMB75 wrote on 2021-02-20, 11:10:
Edit: This one came a little late to the party. It was loosely packed in an envelope... welcome test candidate 1 for 50MHz FSB.
Don't expect much stability or being able to run 3 VLB cards at once...
Reply 38162 of 59674, by debs3759
Gabriel-LG wrote on 2021-02-20, 20:19:
Hail to the king, baby :D GoldenOrb1.png […]
Hail to the king, baby 😁
I never thought I'd find a Golden Orb, let alone NOS. I am so happy 😀
On a side note, I always thought that the Titan Majesty-IV was a Golden Orb rip-off (I was happy to find one nonetheless). However, before installing, I saw that it has Thermaltake stamped on the heatsink... It just makes me wonder why.
I have the same cooler in a box. Didn't realise I had the sought after Golden Orb, as have so many unstarted projects that I hadn't opened the box.
Reply 38163 of 59674, by CMB75
yawetaG wrote on 2021-02-21, 10:38:
I don’t. I’ve got two VLB cards certified and tested working at 50Mhz and I don’t need more than those two cards. Known to work without wait states. The only culprit could be the mainboard as I’m not in possession of an Superboard VLB... but I have a generic Opti895 coming my way.
Almost the setup I had in ‘93.
Reply 38164 of 59674, by crvs
Got these today for $20. Green one is dead, but the gold one has passed all tests.
Reply 38165 of 59674, by Wolfus
Bancho wrote on 2021-02-19, 21:09:
Wolfus wrote on 2021-02-19, 18:48:
Bancho wrote on 2021-02-17, 10:16:
Picked up a very cheap boxed Boss DR-330 "Dr.Synth" midi module with manual today. Battery had started to leak but I removed it and there is no damage. Unit works great
Any chance you bought it from Austria? Along with Roland keys?
No, I bought this off UK eBay.
I was overran by somebody few days ago. Anyway, how do you like DR-330?
Reply 38166 of 59674, by ODwilly
crvs wrote on 2021-02-21, 17:48:
The green one may only work in the pc chips m919 motherboard. IIRC pcchips liked to use non-standard pinouts for some of the COAST slots on their motherboards.
Reply 38167 of 59674, by crvs
ODwilly wrote on 2021-02-22, 07:04:
They are both for m919. That's all the fun 😀
Reply 38168 of 59674, by Gabriel-LG
dulu wrote on 2021-02-20, 23:06:
In which place? I had titan orb but didn`t notice thermaltake logo.
debs3759 wrote on 2021-02-21, 12:46:
It is on the front, on the motherboard side. When the CPU is installed the inscription cannot be seen:
The attachment GoldenOrb3.jpg is no longer available
Reply 38169 of 59674, by pentiumspeed
Back in the day, I discovered one of low quality memory SIMMs had open vias.
You might want to check your non-working pc-chips M919 modules for this.
Cheers,
Great Northern aka Canada.
Reply 38170 of 59674, by shamino
Just won an auction for an Atari 800XL. I'm more excited about that than anything I've bought in a long time.
I never had an Atari computer as a kid but I think it would have been perfect, and I've been admiring them for years.
Finally I took the plunge and bought one. It doesn't come with a PSU, and then I'll find out if it's faulty in any other way, but I think it won't be too hard to get going.
Reply 38171 of 59674, by draetheus
I have taken to scrapping thrift store PCs when looking for optical drives as its much cheaper than ordering them off eBay. First one I scrapped was a beat up P4 Dell circa 2003. Only useful things I got out of it were the DVD drive and some slow DDR 266 RAM. The motherboard had bulging caps, the CD drive was extremely slow and loud, and the GPU was a dirty Matrox G400 that I couldn't get a signal out of on a working machine (3.3v agp maybe?)
Yesterday I scrapped an Athlon 64 HP circa 2005 in much better condition. This has an interesting motherboard, the Asus K8S-LA, which is a SiS 760 board that looks very similar to the K8S-MX. Paired with an Athlon 64 3300+, it makes for a very speedy but compatible Win 98 machine! Funny enough, the CD drive on this system worked, but the DVD drive was busted. It was also missing RAM and had no external GPU, but obviously I had some RAM lying around, and the thrift store had a FX 5200 in a MX440 box for a couple bucks. I now have a second fully functional Athlon 64 system xD. Not sure what I'll do with it other than use it as a part/software tester (although that in itself will be nice to keep my primary Athlon 64 FX build pristine). I will probably rehome it in a new case as I absolutely HATE the fat plasticky bezel look of those mid 00s OEM systems.
The attachment PXL_20210220_185206830.jpg is no longer available
Reply 38172 of 59674, by bjwil1991
Bought the following from TexElec's site:
1) Foam contact pads for the Compaq Portable
2) CF-IDE adapter
From eBay (screenshot):
1) 360KB internal FDD for writing 360KB diskettes
2) 256MB industrial CF card for the Compaq Portable
3) CT1350B w/ the CMS upgrade and comes with manuals and diskettes (for a Sound Blaster Pro and others)
The attachment Screenshot_20210222-202311-516.png is no longer available
Reply 38173 of 59674, by H3nrik V!
draetheus wrote on 2021-02-22, 23:39:
I've had issues back in the days with both G400 as well as G100 where card's BIOS has been corrupted. It didn't show any picture while in text mode, but as soon as it booted into Windows, it worked fine, including running 3dmark etc. Both could be fixed using an automated BIOS flashing floppy. Might be worth a shot?
Reply 38174 of 59674, by draetheus
H3nrik V! wrote on 2021-02-23, 04:16:
Interesting, I'll give it a try with windows preinstalled and see if that works.
Reply 38175 of 59674, by Ozzuneoj
I was never one to seek out boxed hardware, but I couldn't pass up this opportunity.
The attachment 20210221_235234.jpg is no longer available
The attachment 20210221_235241.jpg is no longer available
The attachment 20210221_235255.jpg is no longer available
Cirrus Logic CL GD5434 2MB ISA VGA card, manufactured in 1998... manufactured for who exactly, I have no idea! Can't imagine there was much of a demand for high performance video on the ISA bus at that point.
When I got it it was 100% brand new, unused, aside from the box being opened and a little beat up. The card and books are pristine. One of the disks looked a little warped but thankfully all three of them were able to be read, so I made raw disk images of them with rawwrite. The images are attached below. Feel free to upload them to the vogons library. 😀
The attachment stb_nitro64isa_rawdiskimages.zip is no longer available
I'm looking forward to doing a mass benchmarking of ISA and VLB cards, now that I finally have a CL GD5434 to cover the top end of ISA. This one will almost certainly take the crown in most benchmarks, though I imagine the ISA bus is the bottleneck in 90% of them. I'd like to run benchmarks in DOS, 3.11 and Windows 95 to get the full spectrum of performance and GUI acceleration. Not sure what board and CPU I'll use just yet. Some kind of fast 586 or overdrive most likely. Maybe both in some benchmarks... or a 386 just for kicks? 😀
Reply 38176 of 59674, by CMB75
I bought a NOS MS basic optical mouse in box,
The attachment MS-basic-optical-mouse-NOS.jpg is no longer available
a NOS Orchid Fahrenheit 64 VLB and
The attachment Orchid-Fahrenheit64-VLB-NOS.jpg is no longer available
a generic 486 VLB mainboard with the Opti 895 chipset. I found several brands selling mainboards with an identical layout. Maybe the BIOS string will point me to the actual make.
The attachment Opti-895-VLB-mainboard-D2E.jpg is no longer available
Reply 38179 of 59674, by Warlord
Love it or hate it. It's a matter of taste. Shipping was a killer but all in all for such a rare and unique case I was happy to get it for what i paid.
Feast your eyes on the Asus Vento 3600, a rare and beautiful case from circa 2005.
