Reply 20 of 54, by Anonymous Coward
According to the manual, the expansion slots on this board run at 4.77 MHz even when the CPU is running at 7.16 or 10MHz.
Reply 21 of 54, by Jager
Greetings.
Can you please share ROMs contents of this board? Mine is basically the same (minus half 44256 slots), but with a strange BIOS (same sticker, but with v1.07 written by hand). Both halves that should be even/odd are almost identical, and I think that's why my board appears to be dead (no video, no beeps).
I've attached my ROM dumps, just in case, in raw and intel hex formats.
    1.8 MiB
    Juko v1_07.zip
    122.56 KiB
    117 downloads
Reply 23 of 54, by Predator99
653.39 KiB
1.41 MiB
XT-Juko-ST.rar
6.28 KiB
158 downloads
I have a quite similar one, but without HI/LO Bios. But you should be able to split my file. I had difficulties getting it running because of the weird RAM configuration, but now it works. Try the Supersoft-ROM for diagnosis 😉
Reply 24 of 54, by Jed118
Jager wrote on 2018-11-13, 15:09:
Greetings.
Unbelievably, I obtained the SAME TYPE OF BOARD AGAIN (Hi/Lo, ver 2.01), in a complete computer, with a bootable hard disk and high density floppies, which both work.
I'll be dumping the ROM at some point.
PM me if interested 😉
What's for sale? my eBay!
Reply 25 of 54, by Robin4
If you can put it here online on the forum that would be nice.
If iam going to test my 8086 NEC V30 motherboard i will also upload those roms as well.
Reply 26 of 54, by Jed118
Robin4 wrote on 2021-01-22, 05:23:
That's the plan - it's retrobriting now (indoors, severe yellow,even orange-ness) so it'll be doing that by itself for the next couple days, but yes, I will post the dumps here.
Reply 27 of 54, by Anonymous Coward
Were the ST and the NEST produced side by side? And if so, does BIOS version on the ST correlate to the version number on the NEST? If so, and there were late BIOS releases for the ST but not for the NEST, it should be possible to split the ST ROM into even and odd banks for use on the NEST.
Reply 28 of 54, by Jager
Jed118 wrote on 2021-01-22, 00:17:
Thanks, but I already obtained one from Anonymous Coward. I even restored original one (1.07).
Reply 29 of 54, by Jed118
What are you using to dump the ROM? Usually I use NSSI, but when I run it on the V30, I get a text summary only.
Reply 32 of 54, by Robin4
Jed118 wrote on 2021-02-22, 03:54:
Here iam using an Eprom reader (just bought if from ebay a couple of years ago)
Reply 33 of 54, by Jed118
vgeorgiev wrote on 2021-09-17, 11:35:
Hi all,
I have Juko XT replica. What kind of keyboard should I get ? AT or XT ?
Yep, I just fired up my Juko with an AT keyboard - it told me to go to hell (keyboard locked) - I'm not sure if the previous time I had one it was just a 101-key with an AT/XT switch or that it somehow autodetected what it was connected to, but yeah, a straight-up AT keyboard will not work.
Now that the Nest is out, I might as well start experimenting on it. Will it take an SCSI CDROM and a Radlib card without too much trouble?
I sense a new idea for a Youtube live stream 😁
Reply 34 of 54, by Anonymous Coward
Recently some 8087 clone FPUs from NEC were discovered. Supposedly they are CMOS too, which implies they may be okay at speeds that exceed 10MHz. Anyone else buy one?
Reply 35 of 54, by retardware
Anonymous Coward wrote on 2021-09-21, 01:38:
Wow! Didn't know they ever actually made a V20/V30 FPU.
They seem not have made it into mass production... maybe a it was bit too late for that in 1990.
Demand seems to be high, I wonder whether there are any left soon... and from what kind of appliance they were scavenged.
Reply 36 of 54, by Anonymous Coward
Cpuworld might have more. I’d also be really interested to know where they came from.
Reply 37 of 54, by Jed118
I put in my "order" - does anyone know how this works? Will there be a PM confirmation or something?
Reply 38 of 54, by Anonymous Coward
I got a receipt from CPU Shack. You can always just send him a PM to find out.
Reply 39 of 54, by Anonymous Coward
Here's where those NEC 8087s come from:
Yaskawa Electric JANCD-HA03 Control Board REV.B D70116C PLC AUTOMATION CARD
Search for that on eBay if you want to see a photo.
