First post, by seleryba
- Newbie
Hi Folks. I have an IBM PS/2 Model 70 with broken power supply.
I decided to swap internals of the supply with some modern ATX SFF one. I did it before with one of my IBM PC330 - a lot of cables to manage, but at all the pinout was like a standard AT/ATX power brick.
In this case it's not that easy. I found the pinout on the web:
and while most of that are easy-peasy (-12V/+12V/+5V/POWER_GOOD, DC RETURN is just a GND), one label is unclear.
SYSTEM STATUS.
Do you know what's that and how to provide an equivalent from a ATX supply? Is that something hard-connected to the +5V/+12V/GND rail or something more complicated?
