First post, by tony359
- Member
Hi all
I have installed an external battery on my SIS 486G motherboard and I noticed that after an extended period of time off, the BIOS would reset to default. I found a broken trace (the original battery had leaked and did some damage) and I fixed that. I have to wait till tomorrow to see if that fixed the issue.
I was wondering where is this voltage supposed to be going to prevent the settings from resetting? 'cause I can follow the battery voltage up to a small transistor but then it doesn't go anywhere else. Am I supposed to see that voltage somewhere on the BIOS chip?
Thank you!
My Youtube channel: https://www.youtube.com/@tony359
