Reply 320 of 506, by majestyk
- Oldbie
LeFlash wrote on 2021-01-25, 07:32:I doubt there's an easy generic mod. You have to check to find a trace where your board sends the 3.3V to the CPU and cut there.
The other components that need 3.3V won't be happy with 2.5V. Every board is different in layout.
Exactly.
It depends on the board´s layout. That´s why I had chosen the GA586DX, it already has a diode in the IO voltage line of each processor (probably for decoupling) and I just unsoldered one end and put a second diode in series. The Vcore mod is no big deal either, just change the values of the resistors at the regulators accordingly.
The heat dissipation is about the same as when using regular Pentium MMX 233. The voltage drop is higher (more heat) but the current the Tillamook causes is lower (less heat).
I calculated all this back in the days, made the mods but - due to lack of time- never managed to put 2 Tillammoks in for a test.
Later I gave this board away, I still have one, but this is in use running a neat NT4 machine as FTP server (with regular MMX CPUs).
