First post, by dicky96
Hi guys
I'm struggling to find Windows 98 SE drivers for this old motherboard
Does anyone here have them?
    1.16 MiB
Reply 1 of 14, by gex85
What drivers exactly are you looking for?
Many files are still available at archive.org:
BIOS --> https://web.archive.org/web/20050826104207/ht … d_Platinix2.htm
Drivers --> https://web.archive.org/web/20051128015848/ht … _downloadcd.htm
Audio driver for example (for Analog Devices 1881A): https://web.archive.org/web/20060222102003/ht … nd/ad18819x.zip
For chipset drivers for the Intel 845 chipset, you might want to head over to Phils Computer Lab: https://www.philscomputerlab.com/intel-chipset-drivers.html
Some can also be found here: http://www.elhvb.com/mobokive/Archive/Qdi%20- … vers/index.html
My retro computers
Reply 2 of 14, by dicky96
Thank you. I was looking for Windows 98 SE drivers
I've installed the chipset drivers and audio drivers from the links you posted.
All seemed to install to be OK but when I boot into windows I get a message to say the audio hardware i not responding correctly. If you click it three times then windows continues to load but I don't have any sound.
In the device manager the sound card seems to be installed OK. Possibly the driver link was not the right one?
    294.64 KiB
    696.02 KiB
Reply 3 of 14, by PC Hoarder Patrol
Saw a post on another forum of a user with same board but different OS - WIn 2K SP4. They tried the AD1881 drivers with same effect - SoundMax device manager entries but no sound. Someone suggested to try other sound codecs so having had no luck with ALC201, they tried Crystal 4299, and success! 😀
Reply 6 of 14, by Jed118
So I have the same problem - I can't download from soundcard-drivers.com (I flat out just don't know how) but I got the files from here:
https://www.driverguide.com/driver/detail.php … driverid=228954
Installed them. There is sound, but it sounds like a modem. That someone stepped on. And put underwater. The computer is in pain! Wretched sounds.
I have WinXP installed on this machine as well, and the card there works just fine. It is listed as:
Intel 82801BA/BAM AC'97 Audio Controller.
This site has a few more options, but so far, nothing has worked.
What's for sale? my eBay!
Reply 7 of 14, by Jed118
So I downloaded a file called INF2K that claims compatibility with 98 and when I go to the General tab (in 98's system properties) I get NTKERN.VXD, MMDEVLDR.VXD device loaders for this device could not load the device driver (code2)
It does see the device as the 82801BA/BAM controller though.
Reply 9 of 14, by Jed118
None of those drivers worked. After installing the SoundMax and the Cirrus ones Windows 98 kept autofinding them and installing those over anything else upon OS start / when I asked it to find more hardware. After a few ghost sessions (I have two of these systems, I had an image stored) to restore the baseline, and spending far too many hours on this, I threw a CT4810 at it, disabled the onboard sound (which worked fine in XP) and called it a day.
Strange, as this board came out in 2001 - I don't see why the OEM didn't provide Windows 98SE drivers, as the OS was only 2 years old at the time of the motherboard release. Maybe they did, but as of writing this in 2020, I can't find them.
Reply 10 of 14, by Jed118
OK so this is weird - I just picked up 4 more of these systems, same config as far as I can tell (it was almost a year ago to this date) and I had long repurposed the drive with the XP/Win98 partition, however, I took a copy off a random NEC Celeron machine that had XP/98 (guess what - XP had to be reinstalled 🤣) but whatever drivers were on Win 98 for the sound actually took! I mean, there's no FM synthesis, NSSI tells me it's the same card as in the computers I picked up last year, but the drivers loaded on the image outgoing the NEC are Vinyl AC'97 Codec Combo Driver (WDM)
C:\WINDOWS\SYSTEM32\DRIVERS\vinyl97.sys
C:\WINDOWS\SYSTEM32\VMM32.VXD (ntkern.vxd)
C:\WINDOWS\SYSTEM32\MMDEVLDR.VXD
VIA technologies
File version 6.14.01.4150 built by WinDDK
I'm not sure what to say here - complete fluke?
No direct DOS compatibility though.
*edit - yep all four work.
Reply 12 of 14, by vetz
According to the website the sound chip is as follows:
Onboard Audio(available on PlatiniX 2-A/-AL, PlatiniX 2I-A/-AL)
AC’97 2.1 Specification Compliant
16bit stereo codec
Multiple stereo input mixer
Mono and stereo volume control
Provides onboard Line-in Jack, Microphone-in Jack, Speaker-out Jack with onboard amplifier and MIDI/Joystick Connector
Upgradable to 6 channels audio with CNR card
Notice the 6-channel upgrade option. Also notice what it says on this site:
http://ixbtlabs.com/articles2/roundupmobo/qdi … e-6a-i845e.html
audio controller based on the ALC650 AC'97 codec supporting 5.1 audio systems and having an SPDIF connector.
Did you try the ALC650 driver?
https://web.archive.org/web/20050830084912/ht … lc650_audio.zip
Also did anyone really look on the motherboard to identify the audio chip? I can't tell by the picture, need closeup.
Reply 13 of 14, by Jed118
vetz wrote on 2021-03-03, 10:31:
Thanks for the pointer - haven't had a chance yet.
Here's a pic of the DSP:
ala_borbe wrote on 2021-03-03, 10:04:
man, put jumpers on FPAA and you will have sound
What jumper are you referring to?
Reply 14 of 14, by PC Hoarder Patrol
**EDIT** - Scrub this as I think we've been down this rabbit hole already 🙁
OK, based on your IC pic and this page link
https://web.archive.org/web/20020203214026/ht … _downloadcd.htm
maybe give these a blast 😀
https://web.archive.org/web/20060222084945/ht … Drv/Cry4299.zip
Datasheet
CS4299_06.pdf
713.19 KiB
57 downloads
