First post, by dataino.it
Hi
i can't find information of this card "PRECISE" - CHIP "PARADISE PVC4 38307C"
9 pin output
if is a ega cga card can i use this converter
LINK -> https://www.ebay.it/itm/Arcade-Game-RGB-CGA-E … 7Cclp%3A2334524
for testing (i have only vga monitor)
    368.88 KiB
Reply 1 of 10, by Benedikt
The Paradise PVC4 is a combined CGA+Hercules chip. The CGA part supports the Plantronics ColorPlus extensions for 320x200 16-color and 640x200 4-color graphics, as well.
Reply 3 of 10, by Predator99
The linked converter will not work as it expects analog input but your card has digital out. The description is misleading...
For testing you can simply connect your TV/monitor via Cinch-out, many devices still supoort this.
Reply 4 of 10, by Benedikt
dataino.it wrote on 2021-03-09, 18:59:
I need to change same jumper for the CGA mode ?
Yes, probably. Unless it is in CGA mode, already.
If you get a picture on a TV set, you are lucky and do not have to change anything.
Reply 6 of 10, by dataino.it
I tested this "VIDEO7 VEGA" and no lucky
no signal on RCA connectors
computer give me 1 long beeb , and then start , no signal
on pin 9 of db9 i have ttl signal of 59.6 HZ and on pin 8 a 15.7 Khz
    683.63 KiB
    444.01 KiB
    1.06 MiB
Reply 7 of 10, by Benedikt
Hardly surprising. That one is clearly an EGA card. The RCA jacks on EGA cards were typically feature connectors for optional add-ons, not composite video output ports.
Reply 9 of 10, by Predator99
Benedikt wrote on 2021-03-09, 21:27:
I noticed I own almost the same one, #12 here
EGA Video cards - BIOS image collection
If yous doesnt post play with the DIP switches...switch one after one or compare with the config of my card.
Reply 10 of 10, by Benedikt
That being said, the digital RGBI signals from a CGA card or an EGA card in one of the 200-line modes can be converted to analog RGB with very little circuitry.
The resulting analog signal is what the scaler board wants as input. If it wants a composite sync signal, add an XOR gate with hsync and vsync on its inputs.
