First post, by cyclone3d
- l33t++
As I am working on getting all the drivers for my Sony PCG-XG29 laptop, I was having trouble finding what modem came with this laptop. Still haven't found a driver that will install but I did find this list on Sony's website that lists the modems in their old laptops:
This table provides information regarding the type of modem installed in the notebook.
Notebook Model Modem Information
PCG 705 707 Sony® V.34 33.6KBps modem with 14.4KBps fax capability and speakerphone.
PCG 717 719 729 Sony® internal modem (RCV336ACF chipset) with 14.4KBps fax capability and speakerphone.
PCG 731 735 Sony® internal modem (Rockwell RCVDL56ACFL chipset) with 14.4KBps fax capability.
PCG 748 Sony® internal modem (Rockwell RCVDL56ACFL/SP chipset) with 14.4KBps fax capability.
PCG 808 Sony® internal modem (Rockwell RCVDL56ACFL chipset) with 14.4KBps fax capability.
PCG 812 818 838 Sony® internal modem (Rockwell RCVDL56ACFL/SP chipset) with 14.4KBps fax capability.
PCG 505 series Sony® internal modem (Rockwell RCVDL56ACFL chipset) with 14.4KBps fax capability.
PCG C1X Sony® internal modem (Rockwell RCVDL56ACFL chipset) with 14.4KBps fax capability.
PCG C1XS Conexant HCF V90 56K data, fax PCI internal modem (Conexant RMH56D chipset) with 14.4KBps fax capability.
PCG C1VP Conexant V90 K56 Flex RJ-11 PCI internal modem.
PCG C1MV C1MVP Agere/Ambit T62M159.00 V.90, K56 Flex, V34, V.32bis
PCG F100 series Rockwell HCF 56K PCI internal modem (Rockwell RH56LD-PCI chipset) with 14.4KBps fax capability and speakerphone.
PCG F200 series Rockwell HCF 56K PCI internal modem (Rockwell RH56LD-PCI chipset) with 14.4KBps fax capability and speakerphone.
PCG F300 series Rockwell HCF 56K PCI internal modem (Rockwell RH56LD-PCI chipset) with 14.4KBps fax capability and speakerphone.
PCG F400 series Rockwell HCF 56K PCI internal modem (Rockwell RH56LD-PCI chipset) with 14.4KBps fax capability and speakerphone.
PCG F500 series Conexant SoftK56 data, fax PCI internal modem (RSSI8003 chipset) with 14.4KBps fax capability.
PCG F610 F630 ESS Technology ES56CVM-PCI internal modem with 14.4KBps fax capability.
PCG F640 F650 F680 F690 Conexant SoftK56 data, fax PCI internal modem (RSSI8003 chipset) with 14.4KBps fax capability.
PCG F650K F680K F690K Conexant SoftK56 data, fax PCI internal modem (RSSI8003 chipset) with 14.4KBps fax capability.
PCG FX100 series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG FX200 series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG FX300 series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG FX400 series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG FXA series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG GR100 series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG GR200 series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG GR300 series Conexant SmartMC II RJ-11 V.90 K56 Flex PCI internal modem.
PCG GRX500 series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG N505VE/VX Rockwell HCF 56K PCI internal modem (Rockwell RH56LD-PCI chipset) with 14.4KBps fax capability and speakerphone
PCG NV series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability.
PCG R505 series Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG SR5K SR7K Conexant SoftK56 data, fax PCI internal modem (RSSI8003 chipset) with 14.4KBps fax capability.
PCG SR17 SR17K Conexant SoftK56 data, fax PCI internal modem (RSSI8003 chipset) with 14.4KBps fax capability.
PCG SRX77 SRX77P Conexant-Ambit Soft56 data, fax modem with 14.4 fax capability. Model SmartMC II.
PCG XG9 Rockwell HCF 56K PCI internal modem (Rockwell RH56LD-PCI chipset) with 14.4KBps fax capability and speakerphone.
PCG XG18 XG19 Rockwell HCF 56K PCI internal modem (Rockwell RH56LD-PCI chipset) with 14.4KBps fax capability.
PCG XG28 XG28K XG29 XG29K Rockwell HCF 56K PCI internal modem (Rockwell RH56LD-PCI chipset) with 14.4KBps fax capability.
PCG XG38 XG38K XG39 XG39K Rockwell Conexant V.90 K56 Flex internal modem (Conexant RH56LD-PCI chipset) with 14.4KBps fax capability.
PCG XG500 XG700 XG700K Rockwell HCF 56K PCI internal modem (Rockwell RH56LD-PCI chipset) with 14.4KBps fax capability.
PCG Z505HE/HS Conexant SoftK56 data, fax PCI internal modem (RSSI8003 chipset) with 14.4KBps fax capability.
PCG Z505LE/LS Conexant SoftK56 data, fax PCI internal modem (RSSI8003 chipset) with 14.4KBps fax capability.
PCG Z505JE/JS Conexant SoftK56 data, fax PCI internal modem (RSSI8003 chipset) with 14.4KBps fax capability.
PCG Z505R/RX Rockwell HCF 56K PCI internal modem with 14.4KBps fax capability and speakerphone.
PCG Z505S/SX Rockwell HCF 56K PCI internal modem with 14.4KBps fax capability and speakerphone.
