First post, by Turbo ->
- Member
I've received this Audigy 2 sound card with one deformed PCI lead. Luckily the PCI lead hasn't broken (yet). I'm trying to figure out the best approach for fixing this. All I can think of is to:
- firstly clean the area with isopropanol,
- then add some cyanoacrylate glue on the bottom side,
- then press the deformed PCI lead with two tooth sticks on the card and wait for it to dry.
Any other suggestions?
Even if I do fix it, the card won't be useful for multiple swapping from one system to another. I could only install it into one system and leave it be.
